Old 03-09-2007, 10:50 AM   #1
sleekism
1999 Ford Fairmont Ghia
sleekism's Avatar
Exclamation Engine Missing and other weird shite!
My Fairmont has slowly been developing a miss and is now at the stage where it will miss badly under load i put some injector cleaner in and it helped a bit but it still misses pretty bad going up hills with the occasional shudder at idle as well. It has 135,000 kays on it.
My parents have a series 2 VCT XR6 and they have also started to develop a miss though are not at my stage yet. They hav 128,000 kays.
Am I right in thinking this is the leads? What about the coil or fuel filter?
Also what the hell oil do you put in the VCT? Mine says 5-30 on the filler cap and the manual says 10-30??
sleekism is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 11:07 AM   #2
StealthAu
Start with leads and plugs
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 05:12 PM   #3
blacklabel
blacklabel's Avatar
I'd be sticking with 5w/30 at 128,000km.
My AU Futura has just clicked over 255,000km and I've just done my first change to 10w/30 after religiously sticking to 5w/30. And it goes fine, nice and quiet and smooth,but I swear the car is just a tad sluggish with the fractionally thicker vis oil,than the 5w/30.
So I might just go back to 5w/30 on my next change-
At least by trying 10w/30 you can make a comparison for yourself.
blacklabel is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2007, 05:49 PM   #4
The Monty
Just slidin'
The Monty's Avatar
My mums forte had the same problem. Leads and plugs fixed it.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 03-09-2007, 06:58 PM   #5
sleekism
sleekism's Avatar
Think its the leads i popped the hood in the dark gave it a good rev and watched a fireworks display under the hood
Old 06-09-2007, 11:36 AM   #6
sleekism
sleekism's Avatar
I have pinpoited it to lead number six heres hoping it works.
Would my cat be farked now?
Old 06-09-2007, 11:49 AM   #7
StealthAu
Don't be a cheapscate replace all the leads
Old 06-09-2007, 11:52 AM   #8
sly
Sly like a G6
sly's Avatar
If you can get that far underneath it (safely of course) give the cat a bit of a bump or 2 and see if you can hear loose bits rattling around inside. Exhaust should be cold of course. Umm might not work for you if you have a std manifold, I have pacies and the cat is well back behind the engine where the rubber mounts allow some sideways movement. If your cat is flanged at either end it's easy enough to unbolt it and do a visual check.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 08:06 PM   #9
sleekism
sleekism's Avatar
Well the last person who owned it didn't because there are two types of leads on the car.
I know faulty leads cause missing under load but at idle as well? The lead looks pretty cool the whole thing lights up when the engine is running.
One more thing: where the coil pack is it looks like it is made to hold a distributor as well. Are there any AU's with distributors?
Old 07-09-2007, 07:58 AM   #10
StealthAu
Heyits your car, but you don't even know when they were last changed
Old 07-09-2007, 06:37 PM   #11
sleekism
sleekism's Avatar
Mate I haven't owned it since new and the log book is no help. I've only had her for 10,000 kays I take advantage of resale.
Changed the leads and she's running sweet again and doesn't skip a beat.
Idle still a bit rough (no missing though) should prob change fuel filter or something.
Thread Tools
Display Modes
