Old 06-09-2007, 07:56 PM   #1
sly
Sly like a G6
sly's Avatar
Default Bent bar???
Since doing my BA front brake conversion on the wagon, the suspension has had a knocky rattling noise over bumps on the LHS. Similar noise to worn shocks (not likely cause as I renewed the shocks in the process) or worn 'D' bushes on the rollbar. I've already replaced the 'D' bushes with new Nolathane ones, which made no difference.
Checking it over today the LHS rollbar 'D' bush makes a groaning sound as the bar rotates through it when the suspension is jacked & released. Could this translate to the noise over bumps?
The donor car was supposedly rear-ended, but the LHS rollbar chassis bracket was bent, I've replaced it already. I'm starting to think the rollbar may be bent too & just enough out of alignment with the bush to bind when it turns. I've put fresh lube in the bush twice, no difference.
Would it be worth my while to just get a new rollbar, probably aftermarket? If so, any recommendations?
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring.
Sleeper, anyone?
sly is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
