Old 30-07-2005, 04:41 PM   #1
bakes_eb
bakes_eb's Avatar
Default Clutch problem
I went to buy a clutch the other day as im converting my eb series 2 to a manaul. the guy told me there is to types of clutches 1 for the ea and eb series 1 and another for the eb series 2. i am unsure which one to get as the gearbox is a t5 out of an ea.
cheers scott
bakes_eb is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2005, 04:53 PM   #2
stockstandard
They are different in the way they mount to the flywheel. EA is 3 bolt, Eb is 6 bolt. Have you got the flywheel yet?
I would get the EB one, and if it turns out you have the old flywheel swap it for a new one.
Originally Posted by casper
Yeah, the car is ugly, I can live with that.
stockstandard is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2005, 04:58 PM   #3
bakes_eb
bakes_eb's Avatar
would i be able to use the ea flywheel?
Old 30-07-2005, 05:04 PM   #4
stockstandard
yeah, the clutch mountings are not as good though. You can get the EA flywheel modified to suite the EB-> clutchs, but if you have the choice get the EB onwards clutch and flywheel.
Old 30-07-2005, 05:23 PM   #5
Psycho Chicken
Psycho Chicken's Avatar
If you can get the EB2 flywheel, it's a better clutch.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2005, 06:46 PM   #6
Damo
the 3.9 clutch is also slightly smaller, 241mm as apposed to 4.0 clutch 254mm. I'd go 4.0 clutch or if you allready have a 3.9 flywheel get a Heavy duty 3.9 clutch with a 6 bolt presure plate and get 3 extra holes drille in the flywheel, make sure you get it machined too and use new presure plate bolts. You should get a new thust bearing with your clutch too.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2005, 07:01 PM   #7
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
i've got a six bolt clutch on a 3.9 flywheel... had a machining place bolt the clutch to the flywheel and tap new holes for the other 3 when i got it machined... works ok so far.
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2005, 01:32 PM   #8
bakes_eb
bakes_eb's Avatar
so yous reckon i should just get a 4.0 flywheel. how much am i looking at for one. and is that all i will have to do just bolt it up and everything else should be right?
cheers scott
Old 31-07-2005, 02:08 PM   #9
stockstandard
I dunno how much, but it wouldnt be much. I got a couple spare in the shed but Im guessing you dont live in Adelaide. It will bolt up fine - the only difference is a couple of extra bits for mounting the clutch.
Old 31-07-2005, 02:16 PM   #10
Damo
I paid $30 for a second hand EA flywheels, so I can't imagine a 4.0 one would be much more than that.
Old 01-08-2005, 03:51 PM   #11
bakes_eb
bakes_eb's Avatar
what extra bits will i need to mount the clutch?
scott
Old 01-08-2005, 04:07 PM   #12
BoZZa17
Lovin the Manual.
BoZZa17's Avatar
when u buy a clutch kit
it comes with what u need all it is is a new clutch driven plate and a pressure plate/clutch mounting
it comes in the kit all you need is to buy a manual flywheel. and a clutch kit, and if you want a thrust bearing. i am doing the same thing atm =)
BoZZa17 is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2005, 05:20 PM   #13
bakes_eb
bakes_eb's Avatar
cheers, thanx for that mate.
Old 01-08-2005, 05:48 PM   #14
Damo
my new clutch came with a new thrust bearing. You can use the bolts off your flexplate for the flywheel. You'll need 6 high tension bolts for the presure plate too.
You'll also need a spigot bearing, which taps into the crankshaft.
Thread Tools
Display Modes
