Old 19-08-2012, 09:34 AM   #1
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
Default Suspected blend door problems
Posting on behalf of fellow member Icar. Problem- no heater in a NU 2000 Fairlane, hot coolant getting to dash but no heater. Anyone had this problem? Blend door motor? Any advice really welcome thanks!
Original post-
"Hi- I hope somebody may be able to help,
Had Battery Terninal cracks- That stopped car starting.
Have had terminals fixed-but now the heater has stopped working, check by mechanic doing service, he says he thinks water is still been heated as dash is warm. Thinks it may be the motor that opens the doors that lets out the heat.
I was hoping someone could give me the parts name and a serial number, and where I could get a second hand part please, in or near Western Victoria District.
Thanks in Advance"
I just did a search and got this-
http://www.fordaustraliaforums.com/f...er-not-working
and
www.fordforums.com.au/showthread.php?p=3199369
Have a look at those Icar & see how ya go!
good luck with it!
cheers,Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2012, 12:01 PM   #2
Default Re: Suspected blend door problems
Yes do the self test engine on in neutral at normal operating temperature (pressd MODE and OFF simultaneously) and it should either reset it and solve the problem or give you an error code.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 22-08-2012, 12:16 PM   #3
rowan194
My CC recently went off with the fairies, needed to be reset (the self test mentioned above)
http://www.fordforums.com.au/showthread.php?t=11372661
Hopefully a reset will cure yours.
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2012, 09:02 AM   #4
fordlova8
FEARsome 429
fordlova8's Avatar
Is there any way to do the self test in an AU Forte. My issue is that it blows warm air all the time, I had the same issue with my old EF Fairmont and the self test fixed it but the Forte has no climate only heater and aircon so no "mode" button.
Live by the Ford
Die by the Ford!
1978 429 XC Fairmont GXHELL.
fordlova8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2012, 11:59 PM   #5
No climate control = no computer control = no self test
sorry.
But it sounds like the heater tap has failed - not uncommon.
Old 14-11-2012, 05:22 AM   #6
fordlova8
FEARsome 429
fordlova8's Avatar
That's one box ticked off in the scheme of diagnosis.
Awesome thanks aussiblue.
Live by the Ford
Die by the Ford!
Thread Tools
Display Modes
