14-06-2006, 01:40 PM | #1 | ||
I'm about to try and change the leads on my AUII egas. I've had a bit of a look and you can barely see the coil pack and only really reach it from below and then you cant see anything.
Is there a trick to making it easier? |
14-06-2006, 01:49 PM | #2 | |||||
XR & FPV Owner
When that is out of the way, you can reach through to the coil pack. Make sure you know the order before you remove the leads. Closest to the motor and closest to the fans is number 1 lead, closest to the Air Box is lead 6. (from memory) D :
2005 BF GT (6sp manual - Build #183) 2015 SZ MkII Territory Titanium 2016.75 LZ Focus Sport Quote:
14-06-2006, 03:26 PM | #3 | ||
Back in a Blue Oval
i put mine up on ramps and did it from under the car. was a bit awkward though and i had someone up top disconnecting each lead so i could follow it down and replace them one by one
'13 Territory TX Diesel RWD. The Family Bus '08 Mitsubishi Pajero. The Off-road Machine |
14-06-2006, 03:55 PM | #4 | ||
Just did it via the airbox method. Lucky I've got long arms
Thanks |
Thread Tools | |
Display Modes | |
