Old 12-11-2006, 05:16 PM   #1
Auuteage
Default Going pacemakers, but which ones ????
Great forum you have going here !! :0)
Im going to get some pacemaker extractors. But some questions if I can:
My AU2 ute is on gas, looking under the bonnet, will anyone have trouble fitting them due to the gas gear being in the way?
Im looking for more acceleration in the low to mid range...
So what specific model extractors would this be?
From there Im thinking of a 2/5 inch exhaust with resonator. Not sure if I should get one muffler or two. Thanks!!
Auuteage is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 05:39 PM   #2
bodes-sh
not sure on the extractors, apparently pacemaker ph4499's fit without moving the gas gear, but some people can't get them to fit. mechan1k is having the same problem with extractors, he has a ute on lpg too, as for the exhaust a few of us, me included, have redback 2.5" exhausts, mine has one centre muffler and a rear hot dog, but i have a sedan...it doesn't drone at all and has a nice sound to it, but other people may be able to recommend different brands/types for a ute...
hope that helps a bit and welcome to the forums, i hope you enjoy your stay
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 05:57 PM   #3
kenz
BOSS Pilot
kenz's Avatar
I have a auII egas ute and I've got pacemaker ph4499's fitted and 2.5" system. Ive got about an inch or 2 between the extractors and the converter but havent had any problems with it. It's got hotdog at the front and muffler at the back end because of the restrictions due to the gas setup
Black BAII XR8 Ute
Blue SY Territory Ghia
Originally Posted by CAT600
No matter how good the F6 is (and it is damn good), its missing two cylinders.
kenz is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 06:32 PM   #4
Auuteage
Thanks for that. Helpful accleration/performance increase I gather ?
Old 12-11-2006, 06:37 PM   #5
kenz
BOSS Pilot
kenz's Avatar
Yep it increased more than I expected, it still lacks way to much for me though :hihi:
Black BAII XR8 Ute
Old 12-11-2006, 07:16 PM   #6
JC
Miami Pilot
JC's Avatar
A 2.5" cats back will give you a better note and a slight power increase etc, and in theory extractors should help with increased power & torque, and 4499s are the only ones suitable for an LPG car (the 4480s are too big and interfere with gas equipment).
Ford Performance Club ACT
Old 12-11-2006, 07:58 PM   #7
Mechan1k
Mechan1k's Avatar
Just fitted my PH4499s ... had more room then expected ... hat my factory exhaust heatshield mould further to fit over the extractors ... looks kinda factory still and shields the converter nicely.
I already had a 2.5" cat back system with one muffler ... sounded nice.
Now the note has changed with the extractors .... and i am finding also that mid-range and top-end is freer revving (not that top-end is much anyway due to the restrictor in the throttle body) ... fuel economy is better as well as it's not working as hard around the 80-110km/h areas ... freeway entrance merging is easier ... and so is kick-back acceleration (mind you that could be due to swapping the auto for a stronger built new 4-sp item).
I am happy with them .... time for the cam to installed though ... then the extractors will really help make a difference py:
Old 12-11-2006, 08:27 PM   #8
Auuteage
Thanks Mechan1K and JC
Whats the deal with the restrictor in the throttle body? What does it actually do?
Old 12-11-2006, 08:33 PM   #9
kenz
BOSS Pilot
kenz's Avatar
How did you have them done? Wasnt there a problem with the distance between them and the converter being to little for NSW laws or did you finish moving the converter ?
Black BAII XR8 Ute
Old 12-11-2006, 08:36 PM   #10
Mechan1k
Mechan1k's Avatar
It's there as a venturi to change the intake air turbulance to suck the gas through enough to keep it idling at least ... when throttle is opened though it really doesn't need to be there ... it's mainly for closed loop idle to keep LPG supply to the engine.
In a nutshell. It can be milled slightly ... but not too much as idle will suffer dramatically.
Impco used to make a variable opening mixer ring that was linked to throttle position ... it would open up more as throttle was opened. They are available in the UK ... but price has gone through the roof ... and other mods need to be done to adapt it to the EGAS engine.
Best to keep the standard setup. Also changing the intake pipe from the airbox to the throttle body can be changed to a mandrel bent larger item ... I found it made a 5rwkw difference on the dyno (thought I'd test it with one lying around at my mechanics workshop) .... I was surprised with the increase.
Old 12-11-2006, 08:40 PM   #11
Mechan1k
Mechan1k's Avatar
I thought it was going to be too close to the converter ... I have the factory manifold off to remove the head (which didn't want to come off .. so the engine was replaced with the newer one) ... so i decided to try and fit up the exctractors ... my LPG mechanic was happy with the distance as long as the shield was in place.
the law is 150mm between converter and heat source ... but it much less as long as a shield is in place over the heat source ... or a converter shield (that Boral sell for the Vialle items).
I had my factory exhaust manifold shield bent out further and moulded to fit over the Pacies and all was good.
No need to move the converter ... I made the provision to allow it to be moved (getting a BA header tank and hose to the radiator) ... just needed a bracket to move it and change the water and gas lines slightly. But in the end ... no need ... WOOT.
Old 12-11-2006, 08:44 PM   #12
Auuteage
Can anyone in Melbourne recommend anyone who could do this install on a EGas ute?
Old 12-11-2006, 08:46 PM   #13
kenz
BOSS Pilot
kenz's Avatar
Yeah I just had my heatshield moulded out over the paccies aswell
Black BAII XR8 Ute
Old 12-11-2006, 09:07 PM   #14
private9
www.TUFFCARPARTS.com
private9's Avatar
If you don't mind my asking, what are the PH4499's worth?
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 09:45 PM   #15
kenz
BOSS Pilot
kenz's Avatar
I think they are about $400-$450 dont quote me on that though
Black BAII XR8 Ute
Old 12-11-2006, 09:49 PM   #16
Mechan1k
Mechan1k's Avatar
I was lucky ... I bought mine from a member on another forum ... they didn't need them anymore ... brand new in packaging with bolts ... $350 ... so I was happy with that.
Old 12-11-2006, 10:19 PM   #17
private9
private9's Avatar
Good stuff! And from the sounds of things, you fitted them yourself?
If so, how hard would you say it is? Straight bolt up to the existing cat?
Old 12-11-2006, 10:40 PM   #18
Smoked
Burnin Rubber
Smoked's Avatar
Standard cat will require modification.
2001 AUII Forte (LPG)
K&N Air Filter
Tickford Air Intake
***Coming Soon: Clear Side Repeaters***
Originally Posted by The-ShowStoPPa
...dont get me wrong this 3.8v6 is pretty special, it does come with the popular shake rattle and roll option and the auto compliments this with the ever popular snap crackle and pop feature
Smoked is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2006, 10:45 PM   #19
Mechan1k
Mechan1k's Avatar
With the help of a mate ... had to drive it to the exhaust shop to get a new cat (old one was starting to spit bits out (mind you ... EGAS really shouldn't need it ... but put one back in cos of legalities).
New cat and small amount of pipework with flange and gasket was $400 inc. labour. Had to drive to the exhaust place with extractors on only ... drove like crap ... sounded mad
Extractors were easy to bolt up though ... with airtools and decent compressor at the mechanics where I always do work on my car ... he lets me do my own work there ... and if I need a hand ... they help.
Old 12-11-2006, 11:22 PM   #20
AU3 HERROD XR8
XR8 M8
AU3 HERROD XR8's Avatar
hey guys, i don't wanna steal auuteage's thread but since the exhaust talk came up.. I'm sure some of you have seen the Herrod Quad Exhaust System on some BA XR8s (twin tips on both sides) I don't know if it's just Herrod that makes it but I saw it on Herrods site. Anyway my question is I know that due to the petrol tank not allowing the exhaust system reach the other side, but would it be possible to throw in a BA petrol tank into an AU and maybe the quad exhausts might work:P I'm thinking that the quad exhausts don't work because of the shape of the AU and BA petrol tank are different, correct me if I'm wrong but this idea just came into my mind RIGHT NOW after going through the Herrod site and I can't go and check under the xr now because it's dark.
The King of the jungle doesn't whistle.. he roars!
AU3 HERROD XR8 is offline   Reply With Quote Multi-Quote with this Post
