11-01-2007, 02:27 PM | #1 | ||
I am currently rewiring a EA falcon for the Speedway in NZ and need some advice, i have found out that i need to move the computer to a safer location, and deloom most of the car, but am a bit scared to just start cutting wires off... any advice would be appreciated...
11-01-2007, 05:11 PM | #2 | ||
Oops, I slipped....
What parts of the loom do you need to remove? Most (if not all) speedway classes in Australia use a carby rather than EFI.
The brake light/headlight/heater/radio etc etc looms won't effect how the car will run. You could follow the ECU loom to the engine bay and just keep that one in, if it's attached to the motor, there's a fair chance it's part of the ECU loom. Does the car have the dash in it still? If it does, I'd mount the ECU to a flat piece of steel replacing the glovebox, or if it doesn't have a dash, make a small stand up and mount the ECU to the firewall.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
16-01-2007, 11:57 AM | #3 | ||
: I have removed everything that does't appear to be attached to the computer, but a mate suggested that i keep the speedo cluster to keep an eye on oil press and temp, but not sure. the last EFI car i helped buld up was a commodore, : , and ended up having to wire the speedo back up as it has a rev limitor.
i just worried i will run into the same problems with this one. as the CPI and the Distributor are all electronic. |
16-01-2007, 12:14 PM | #4 | ||
PM me if you want
I have a complete wiring pin assignment for an EA series MPFI 3 speed auto computer.
EA Series 1 - ECU PIN wire colour Description 1 yellow Keep Alive Memory Power 2 3 white Vehicle Speed Sensor 4 5 red/green Key Power - B+ when igntion is switched on 6 yellow Power Steering Pressure Switch 7 greeen/yellow Engine Coolant Temperature sensor 8 9 10 blue Air Con Clutch Relay 11 12 13 14 15 16 black Ingition Ground 17 white/black Self test output 18 19 20 21 grey/white Idle Speed Control Device 22 brown/green Fuel Pump Relay or circuit 23 24 25 yellow/red Air Charge Temp 26 orange/black Sensor Volatge Ref +5v 27 28 29 green/blue Heated Exhaust Gas Oxygen sensor 30 orange/black Neutral Drive switch 31 yellow/blue Canister Purge enable output 32 33 34 green/yellow Serial Data Output Port (Link) TRIP Comp 35 36 yellow/green Spark Output from the EEC IV 37 red Vehicle power B+ 38 39 40 black/green Vehicle ground battery negative (-) 41 42 43 44 45 blue/yellow Manifold Absolute Pressure 46 black/white Zero ref for most sensors 47 green/black Throttle Position Sensor Voltage 48 white/red Self Test Input 49 grey/blue Heated Exhaust Gas Oxygen sensor GND 50 51 52 53 54 55 56 brown Profile Ignition Pulse 57 red Vehicle power B+ 58 dark brown bank 1 59 green bank 2 60 black/green Vehicle ground battery negative (-) EDIT: I have also re-wired my car for complete hidden wiring in the engine bay, so if you need further help on any wires just ask
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
