Old 15-01-2007, 06:31 PM   #121
Damo
you forgot the spigot bearing!!!! OMG slap one in and drive the bastard!!! ok ok it's your car, atleast you found what the problem was which is allways a good thing.
Damo is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 06:48 PM   #122
Psycho Chicken
Psycho Chicken's Avatar
Best advice bar one thing. Get someone else to put the spigot in and do up the flywheel bolts.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 07:12 PM   #123
John_LS1
Posts: n/a
Originally Posted by EF_Frmnt
Yeah but most low comp pistons are not fly cut with recessions for the valves.. low comp is just a big f-off dish high comp has fly cuts, and there is usually no swirls or any bowl type machining done on low comp pistons. Ive never seen low comp pistons with fly cutting done.. any pics or cars that do have them??
true, with enough dish there wont be fly cut. im pretty sure the xr6t ones are fly cut to suit but with forgies im sure there will be a few options just make sure you run enough boost to make up for the really low comp :P
Old 15-01-2007, 07:14 PM   #124
efgiar
rofl copter
efgiar's Avatar
found out today all ba pistons have a floating gudgen pins, so the require a circlip. they wont go into au rods unless the series 3 came with the same set up?
GQ patrol.
thats all
Old 15-01-2007, 07:41 PM   #125
Rmyers
Does Steve have a car?
Rmyers's Avatar
Everyone makes mistakes mate, in this instance it would have been usefull to have a gregories on hand, but the fact that i've come this far with the car WITHOUT one surely implies that i can handle placing a bearing in and tightening 6 bolts. As i said before the bolts were tightened properly, it's simply the oversight of that bearing that caused them to loosen...
Efgiar: Yes there is slight play in the input shaft...
Well anyways guys the the Auto is almost done, so hopefully she'll be back on the road soon enough
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 08:09 PM   #126
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Not always. You should locktite them.
Spiggot bearing is like not putting the brake pedal back in when doing the interior. It's an integral part of the 5 speed.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 08:25 PM   #127
EF_Frmnt
EF_Frmnt's Avatar
Did say Ba 'rods and pistons' ;) ...... i have seen quite a few naked ba motors as well as ef/au setups.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2007, 09:11 PM   #128
Rmyers
Rmyers's Avatar
I've said numerous times already that they WERE loctited....
AKA Mr Silver
Old 15-01-2007, 09:35 PM   #129
Age182
GMHKLA number plates
Age182's Avatar
i just got my auto back from the trans shop today
Fully Rebuilt
97LE V8 Valve Body Modified
Shift Kit Stage 2
$2090
9.1/2" 2700 Dominator Stally
$750
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2007, 01:15 AM   #130
Rmyers
Rmyers's Avatar
Fully Rebuilt
Shift Kit Stage 2
$2090
$750
Not cheap is it :P
AKA Mr Silver
Old 16-01-2007, 07:36 AM   #131
LTDHO
The one and only
LTDHO's Avatar
Fully Rebuilt
Shift Kit Stage 2
$2090
$750
They're not cheap units huh?
At least you got a good convertor, I ran a Dominator in my XE.
Why are we talking about your car? This is Steves thread!
Hey Steve, how's the EA coming along.
1992 DC LTDHO 360rwkw built by me
Tuned by CVE Performance
Going of the rails on a crazy train
Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
LTDHO is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2007, 10:03 AM   #132
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
Yeah good question where we at? Is everything done on the outside and interior? Are we just up to your trans decision?
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2007, 01:37 PM   #133
Rmyers
Rmyers's Avatar
The Auto has been raised into position but we were having problems with the top shroud wedging itself against the flexplate. We had it bolted on but we couldn't turn the motor over by hand, so we hadto to pull it back a little and found the shroud has has it's corners bent. I'm either going to haveto get a new one or try and straighten this one out. Once this trans is in the car will be 99% finished, the other 1% include stuff like HU, HU facia etc...
AKA Mr Silver
Old 16-01-2007, 05:30 PM   #134
Psycho Chicken
Lack of a spigot won't loosen the flywheel bolts.
Old 16-01-2007, 05:34 PM   #135
efgiar
rofl copter
efgiar's Avatar
no but lack of spiggot bearing will make the noise. loosening of flywheel bolts can be anything, not done up tight enough for example, even with loctite it can still come off. using an incorrect locktite can do it also.
GQ patrol.
thats all
Old 16-01-2007, 06:04 PM   #136
Psycho Chicken
Even with no loctite they would of lasted longer. I've only put loctite on flywheel bolts once and never had an issue.
Old 16-01-2007, 06:08 PM   #137
efgiar
rofl copter
efgiar's Avatar
yeah but if the bolts were a little worn, had oil or grease in the thread it may not have cured proply, the fact is they have come out, use more loctite next time and ensure the bolts are clean.
GQ patrol.
thats all
