27-01-2007, 09:37 PM | #1 | ||
I recently went to my mechanic for a quote to change my head gasket. I explained to him that coolant is starting to leak out between the head and block near the 3rd cylinder. He told me that its a fairly common problem for the head to corrode there and that in the worst case scenario, I'd be up for a replacement head for $1400 fitted. I asked whether it would be replaced with a Tickford head and he told me that I cant get one as there is no part listing for this head in his book. He also said that there is no difference in the casting of the head but the cam is different from standard.
Now, I'm almost certain that I've read somewhere that the tickford head has smaller combustion chambers and larger valves, along with the cam, compared to a standard head. Can anyone set me straight? Also, for under $1400, I can pick up a complete BA twin cam motor rated at 182kw. How much rooting around would it be to make it fit in an EF? |
27-01-2007, 10:43 PM | #2 | ||||
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
27-01-2007, 10:52 PM | #3 | |||
Gunna girlie-man
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done |
27-01-2007, 11:08 PM | #4 | ||||
28-01-2007, 01:44 AM | #5 | ||
In answer to your first question yes there is a diffrence in xr6 heads.
Tickford alloy cylinder head including: Larger valves (41mm dia valves replacing std 39mm). Reshaped exhaust ports / runners. Reshaped intake runners at the valve mouth to improve incoming 'air tumble and flow dynamics'. Identifiable by a 'T' cast into the front of the head. Check out this website if you wanna know everything that was diffrent http://www.trueblueford.com/EFxr_specs.html |
28-01-2007, 01:54 AM | #6 | ||
Now XR8TickfordBoy
Might be worth looking around for a second hand Tickford head from a wreckers or somethin as I doubt ud want to downgrade to standard heads as the Tickford heads are much better! As said prob some better options for $1400!
EF XR8- Respray in Monza Red with Clear Coat, Custom Rear Bar, AU V8, EL GT MAF, Rebuilt and Strengthened Auto with Stage 2 Shift Kit, 2,500RPM Stallie and tranny cooler, Rebuilt Diff with 4.11 Gears, Custom Radiator, King Ultra Lows, Pedders Shocks, NL Concorde Rims. |
28-01-2007, 02:05 AM | #7 | |||
either way there are better ways than buying a new unit . |
28-01-2007, 08:22 AM | #8 | ||
SnortPerformance.com
Or for less than $1400 you could get a complete AU motor with the modified sump to fit EF/EL an just drop that in.
28-01-2007, 11:24 AM | #9 | |||
Tuned @ Pitlane Frankston
It won't be the head thats corroded, it'll be the gasket. The head can be reco'd for around $500 (that's a full reco). And you'll have your tickford head. He probably wants to flog the tickford head off, and fit a standard one to your car. shifty bugger.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
28-01-2007, 12:10 PM | #10 | ||
Smash the Boost
No, the alloy does corrode as well. Only one of my eseries heads (i have done three) has been able to get away with a skim. The other two needed welding around the water jackets between cyls three and four
2023 Hyundai Palisade 1971 Fairmont Sedan 1974 SWB F100 Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
28-01-2007, 12:13 PM | #11 | |||
28-01-2007, 02:53 PM | #12 | ||
He said that the new head would be the absolute worst case and that $1400 was the max it would cost. He didn't rule out that it might be the gasket and went over the whole weld and skim thing. The main thing that made me a bit iffy about it was the fact that he wouldnt be getting another Tickford head
28-01-2007, 05:13 PM | #13 | ||
How much did he say if the head turns out fine after pressure/crack test etc?
29-01-2007, 12:44 AM | #14 | ||
He didn't say. He usually does me a pretty good deal coz he went to school with my sister. He mentioned that the top gasket set would be around $100 (head, manifolds etc) and for labour I'm not sure.
29-01-2007, 11:21 AM | #15 | ||
I build your wish list...
Permaseal gasket set = 48+
Head bolts = 21+ AU Head gasket 50+ Machine head , Pressure test 80+ Weild any Holes ?? 25 for the first one and 10 for every one after that. then there is the time to do it . It takes 4-5hrs to do a e-series @ 70$ a hr a short job like that will come to around the 600 mark. BUT then again EVERY Place and Mechanic charges diffrent. To do this same job at the next place down the road they will charge 850 - 1000.. even a exchange head is less then 500.. AND Now they are Making Brand NEW heads for E-series. I think they are $300 NEW but with no springs or valves
If it weren’t for physics and the law enforcement, I’d be unstoppable.
30-01-2007, 08:07 PM | #16 | |||
