21-06-2007, 01:04 PM | #1 | ||
1999 Ford Fairmont Ghia
I was having a chat to a mate who has a XH XR6 ute with the XR6 HP motor modded with NOS and a supercharger and I responded that since his was the HP and mine is the VCT with the same mods mine has the potential to make more power.
The Tickford Sixes don't seem to have the same information as other engines on the internet so I'm not sure if my statements are justified. I mean is the VCT motor based on the HP with the addition of VVT or is it based on the lower Intech motors basically does it have the same air flow characteristics as the HP? Also is the HP motor the same as the EF/EL with the larger ports or is it based on the AU small port motor? What does Tickford actually do to the Intech motor to increase power and torque ? How much can the valve timing be changed in the VCT motor and is there are aftermarket support to cahnge the valve timing and what sort of power can be made? I have heard some people say that the VCT was added for fuel economy not extra power but seeing as Ford officially rates fuel consumption higher in the VCT over the HP this seems stupid. I have seen the results Casper has got with his VCT but has anyone done this with a Fairmont Ghia? I am currently booking in soon for 2.5 inch cat back and a bit further down the track Pacemaker extractors what power figures can I expect to make and how much performance would I gain? I have heard that fitting an XR6T snorkel helps but looking at the intake it doesnt look that restrictive would I gain any power from it? I'm looking for around 7.5 to 100kays and low 15 quarter miles at a good price but would probably look at different diff if need must be also would it be too difficult to fit XR6 shocks to my Mont and would it improve handling? |
21-06-2007, 01:53 PM | #2 | ||||||||||||
I havent actually touched my engine yet.. all bolt on's. Anyhow, I'll try to answer what I know (or what my opinion is) anyhow.
All the AU engines were basically identical except for the heads. The Heads are what seperate Intech from HP from VCT. That said though the VCT has some unusual exhaust flow traits that seem to make it more fussy when it comes to fitting headers. Quote:
21-06-2007, 02:46 PM | #3 | ||||
lift HP inlet 6.743 exhaust 6.434 VCT inlet 6.717 exhaust 6.434 timing HP INLET OPENS @ 14 DEG BTDC CLOSES @ 68 DEG ABDC VCT INLET OPENS @ 12 DEG BTDC CLOSES @ 72 DEG ABDC HP EXHAUST OPENS @ 56 DEG BBDC CLOSES @ 24 DEG AADC VCT EXHAUST OPENS @ 58 DEG BBDC CLOSES @ 24 DEG AADC Quote:
21-06-2007, 02:49 PM | #4 | ||||
What I was referring to was the cam dial in. In a HP the dial in is basically neutral. In the VCT the dial in is both advanced and neutral.. depending on what rpm the car is doing.
21-06-2007, 02:58 PM | #5 | ||
_Oo===oO_
We wanted the IRS weight, not your weight Casper, 70kg difference it is he he.
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
21-06-2007, 03:01 PM | #6 | |||
Either way, the VCT is a significantly heavier sedan option for option.
21-06-2007, 04:30 PM | #7 | ||
_Oo===oO_
So in short: heavy, thirsty suckers that take a little bit of fiddling to get going fast.
Now about those shocks: Monroe GT's (badge engineered Motorcraft Reds - as fitted to XR's) are pretty average really, much better options out there than that.
21-06-2007, 07:59 PM | #8 | |||
21-06-2007, 08:20 PM | #9 | ||
Just another mock-up..
is changing the standard VCT ecu to a xr6 ecu just unplugging the old one and plugging in the xr one or do other things have to be changed?
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
21-06-2007, 10:34 PM | #10 | ||
you need to reprogram the ecu and bem if you change the ecu, for the sake of it, just get the edit done, then you can get it set up exactly how you want it
21-06-2007, 10:46 PM | #11 | |||
FF |
22-06-2007, 01:10 AM | #12 | |||
22-06-2007, 06:39 AM | #13 | ||
Built Ford Tough
VCTs came with different headers, HPs came with forte exhaust as well from memory.
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
22-06-2007, 08:01 AM | #14 | |||
22-06-2007, 10:08 AM | #15 | |||
22-06-2007, 12:41 PM | #16 | |||
22-06-2007, 06:42 PM | #17 | |||
Back to the AU
2001 Ford AUIII Falcon XR8 Manual - Can't get enough of the AU 2001 VW Bora V6 4Motion - If I squint it almost looks like a Sierra Cosworth |
22-06-2007, 07:01 PM | #18 | |||
23-06-2007, 01:18 AM | #19 | |||
Back to the AU
That's encouraging Casper! Even if it is only 2 stage, being able to adjust the VCT will open the doors a lot for new cams. Keep us posted mate, or even better, let us know where we can keep track of progress.
25-06-2007, 01:16 PM | #20 | ||
This is quite interesting information.
A lot of workshops dont seem to touch the VCT beyond the basic bolt on mods. |
25-06-2007, 02:58 PM | #21 | |||
25-06-2007, 09:24 PM | #22 | |||
when i got my AU IRS shipped over it weighed in @ 75 kilo on the shipping scales and was recorded on the docket. and from memory its not that heavy as 2 ppl can carry it no worries i can carry a normal diff by myself but i dunno how much they weight. |
26-06-2007, 01:29 PM | #23 | ||
70 kilos aint a lot really!
I can save probably nearly 300 kilos by kicking my mates out of the car or make up for it with a simple exaust. I cant wait to see further developmants of the VCT imagine if it had the level of aftermarket support RB's and Ecotecs had. |
26-06-2007, 09:47 PM | #24 | ||
_Oo===oO_
70 kg on a 1600 kg car is almost 5%. Might not matter on the road, on the track though might be a different story.
26-06-2007, 10:03 PM | #25 | ||
Fordless
On a race track it's a definite burden but in the real world on average roads the AU IRS more then makes up for it in ride, handling & traction.
26-06-2007, 10:09 PM | #26 | ||
not here much anymore
wasnt there a bloke on old aufalcon website who was doing a bit to his Ghia? Black Pig or something?
2024 F150 XLT
27-06-2007, 03:53 PM | #27 | |||
27-06-2007, 07:32 PM | #28 | ||
ok, can you tell me what the differences are between the std intech and the hp engines? and is there a visual way to tell them apart??
cheers, paul.
i was going how fast officer? |
27-06-2007, 07:38 PM | #29 | ||
Visually-red powdercoated head and tickford badge.
I will let the experts fill in the rest i'm not 100% but I think they have larger ports than std and different headers. |
27-06-2007, 07:39 PM | #30 | ||
