Old 17-01-2007, 02:40 PM   #1
autickfordfairmont
Tickford Equiped
autickfordfairmont's Avatar
Default TS50 Driving Lights Mounting
Hey guys,
Just got fitted a TS50 Bar to my car. Just seeing how everyones driving lights are mounted. Mine they have made up a bracket from the bottom of the bar and bolted to that, but i dont like that idea as the bar will flex which will move the lights. I would rather mount as it shows on the AWC website for the XR50 bars. How do the genuine TS50's mount and how have others mounted. Pics would be great.
Cheers Col.
Oh heres a pic of my bar.
Genuine Tickford Equiped 1998 AU Fairmont
Mods: ....... Dash mat & Air Freshener, does that count as a mod??????
Sports Exahust, Tickford Intake Snorkle, K&N Filter, NGK Plugs, Top Gun Leads
TS50 Front Bar with Fog lights, TS50 Rear Bar. Injected LPG System,
autickfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 03:20 PM   #2
T3man
T3man's Avatar
So is it a Ford bar? I'm assuming it is ... in which case there are two re-inforced legs moulded into the lower tray of the bar. The OE (I notice from the pic yours aren't) lights have a metal platform (inverted u-shaped) which mounts to the legs and then in turn the light mounts to that platform and incorporates a simple adjusting mechanism. Yes there can be vibration which can cause damage to the plastic light housing on the OE lights. But movement of the lower bar never causes light movement which is noticeable when driving (at least not until the bodies crack LOL).
Old 17-01-2007, 03:46 PM   #3
autickfordfairmont
Tickford Equiped
nah, its an AWC fibreglass bar, so alot more flex when driving than a plastic one on the lower part of the bar. Thanks for your info though, seems to be a similar method of mounting (A little different). Cheers
Old 17-01-2007, 05:57 PM   #4
GlennBA
GlennBA's Avatar
I'd say there'd be less flex with fibreglass to be honest.
GlennBA is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 06:00 PM   #5
Bucknaked
Bucknaked's Avatar
the bottom of the genuine bar has a mounting point. its the bottom directly under the the light opening. The light mounts to a big bracket and then you screw the bracket to the bounting points on the bar. You can adjust the lights that way, is really easy.
This mean's the best way for you to mount your lights would be as per AWC's web site.
Bucknaked is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 06:51 PM   #6
chief
FTF Club Moderator
chief's Avatar
Here is the article on how to fit your lights. http://www.awcinfo.com/techxr50.htm TS50 and XR50 use the same method to mount the lights.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 09:25 PM   #7
qldwagons
auto elec and aircon
qldwagons's Avatar
Default driving light brakets
does anyone have the dimensions of the brackets etc ?
cause im also after a set also with awc bar
autickfordfairmont might see you around im in currumbin waters with au wagon with ts 50 frt
au2 ts40w wagon
qldwagons is offline   Reply With Quote Multi-Quote with this Post
Old 17-01-2007, 11:59 PM   #8
T3man
T3man's Avatar
Sorry, that is nothing like a TS50 - at least not on the Series III - not even the same light.
Old 18-01-2007, 12:03 AM   #9
chief
FTF Club Moderator
chief's Avatar
This is for an aftermarket light. Not a genuine one. Since the XR50 uses a bottom half TS50 bar its a good indication.
Albert Einstein:
Old 18-01-2007, 07:39 AM   #10
T3man
T3man's Avatar
It's not the same mounting method - not that it doesn't work for the aftermarket lights, but it certainly won't work for the FF200 Hella lights that Ford used.
Old 18-01-2007, 03:11 PM   #11
autickfordfairmont
Tickford Equiped
thanks guys for the info. If anyone has dimensions of the bracket AWC use that would be great.
qldwagons yeah may see you around. Im in real estate so Im always on the road. I will keep an eye out for you.
Old 18-01-2007, 03:45 PM   #12
JC
Miami Pilot
JC's Avatar
I have a set of AWCs brackets at home somwehere. I'll see if I can dig them up I'll post the dimensions in this thread later tonight.
Ford Performance Club ACT
Old 18-01-2007, 05:55 PM   #13
autickfordfairmont
Tickford Equiped
thanks mate
Old 19-01-2007, 06:39 PM   #14
qldwagons
qldwagons's Avatar
just a question what brand /size lights are you using with the fibreglass ts 50 frt bar ?
au2 ts40w wagon
Old 19-01-2007, 09:06 PM   #15
JC
Miami Pilot
JC's Avatar
Oops - spent 3 hours longer on zhodaks car than I thought, so forgot about this. Will get the measurements now and post them up!!
And here it is:
Old 20-01-2007, 09:51 AM   #16
autickfordfairmont
Tickford Equiped
qldwagons, they put in a set of 100mm Narva Driving lights.
http://www.narva.com.au/ForwardLighting_3.html
I have just checked out there website and would have rathered the next set, they have built in angel eyes, which would look mean hooked up with the parkers.
http://www.narva.com.au/ForwardLighting_4.html
Thanks JC for those measurements. Muchly appreciated.
Cheers Col.
Old 20-01-2007, 11:36 AM   #17
T3man
T3man's Avatar
Heheheh - 100mm Narva driving lights don't throw as much light as the standard XR headlights - might as well put the fog version down there and at least it would be something you could make use of.
Old 20-01-2007, 12:28 PM   #18
autickfordfairmont
Tickford Equiped
There alright, light up the road fairly well, i do alot of highway running so i like to run with them on and just the parkers, otherwise i go through to many Headlight bulbs, and thats where my real source of light at night is. I have them pointed low so they dont shine in anyones eyes, but are still visible, and i have them aimed to fill in the dark spot you get at night when using high beams when its raining or has been raining and the road gets very very black (If you know what i mean). Even set higher as driving lights they put out a pretty good beam, i can easily light up things down the road, they shine all the way to the end of my street and light up houses & trees very well, and thats a good 170-200 odd metres. So not to bad, funny you mention it though i would have rathered the fog ones in there, would suit my purpose alot better, but they will do for the time being.
Old 20-01-2007, 12:53 PM   #19
T3man
T3man's Avatar
Yep, they are a good spread beam style driving light - and they are very good at filling in the shadows that the standard AU lights leave all over the road.
When I made the comment about the XR lights - you have standard AU so it wasn't directed at you as such - but I have to laugh at AWC for fitting them (Narva 100s) into the lower bar on the XR50 stlye when used on an XR - the lights would be a total waste of time.
Old 20-01-2007, 06:03 PM   #20
qldwagons
qldwagons's Avatar
thanks jc and au tickford fairmont, lights ordered and brackets about to be made
au2 ts40w wagon
Old 25-01-2007, 03:04 PM   #21
autickfordfairmont
Tickford Equiped
Oh yeah also, can you guys post up some pics of your Exahust Tips... The cuttout is huge, perfect for twin tips, just havent decided what type yet, if you could post up pics that would great.
Old 25-01-2007, 03:18 PM   #22
JC
Miami Pilot
JC's Avatar
Just copy Bucky's - they look great (if not ricey, on his pea shooter).
Old 25-01-2007, 03:19 PM   #23
JefXR8
JefXR8's Avatar
personally i dont like the twin end,i like the one big oval one,im going to have 2 of them out the back of my ute
JefXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2007, 05:03 PM   #24
autickfordfairmont
Tickford Equiped
yeah bucky's do look good, would like something similar. Do his come out even or are they slightly offset to go with the curve of the rear bar? I cant quite see in the pics of his car.
Old 15-07-2007, 01:44 AM   #25
cilkorules
Default hi just clarifying what has bee said so far
And here it is:
those brackets you showed, did't acuatally say what they bolt up to in which position, or which holes on the bracket connected to what parts of the car or light bracket, i have this same dilema with my ts50 front Bar as its fibre glass and i need to know what lights i should purchase?? , and is this the right bracket for me my car(shown above) my car is a AU series 2 and my front BAR is a TS 50 fibre glass not-origional, i purhased aftemarket lights but i want to pt the right lights in cause the monza lights I have are gay they have LED's in side and look weird, what driving lights are most prefered and what is the best way to install my lights. Cause looks and first impressions last a life time and a custom ride is something special. thanx pplz let me know what i should do next. don't complain about spelling errors. thanx Karlos
cilkorules is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2007, 03:42 AM   #26
JC
Miami Pilot
JC's Avatar
Go to the AWC site, and they have fitting instructions and light sizes there, but no measurement on the brackets. So combine their stuff with the bracket dimensions I posted, and Jack's your uncle's mate.
OT - ironic that the sentence you managed to spell correctly is the one asking not to complain about spelling - which shows you can do it, you just don't want to! (insert whatever smiley you like here).
Old 15-07-2007, 11:53 AM   #27
bodes-sh
give this a try, it should give you some idea http://www.awcinfo.com/techxr50.htm
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
