16-07-2007, 11:18 AM | #1 | ||
Okay my car has finally died in the .. at first i thought it was a leak becasue it wasn't really pointin to the signs of a blown head and about 20 mintues ago when i parked at my house i though i'd take a quick look to check up on it..
I was horrified the dip stick was watery and milky, coolant was blowning bubbles and the car started to sound like . now would it be cheaper to just get a new gasket or a whole engine(if so how much), the car has done 247,000 km so im leaning to the engine please help.... |
16-07-2007, 12:00 PM | #2 | ||
Spin 'em Habib !
Might be Cheaper these days to find a Low K's AU Engine , some can be found for about 500 bucks ..
AU2PWR |
16-07-2007, 12:07 PM | #3 | ||
Price depends on how much you can do yourself, but you have to remember that these engines are very common for blowing headgaskets, so you may buy and fit a 2nd hand motor and then have a blown headgasket in a few months time and you'll be back to square 1.
If your motor appeared to be ok before blowing the gasket, you are better off replacing the gasket and maching the head and at least that way you should be ok for a while
16-07-2007, 12:30 PM | #4 | ||
thanks for your help guys i found this on ebay just before...
http://cgi.ebay.com.au/Good-low-K-AU...QQcmdZViewItem i rang around before aswell and to replace a head gasket would be any where between 700 - 1200 dollars |
16-07-2007, 01:09 PM | #5 | ||||
Back to Le Frenchy
16-07-2007, 01:12 PM | #6 | |||
16-07-2007, 01:25 PM | #7 | ||
Flairs - Truckers Delight
the AU has a steel head gasket and i've seen dozens of cabs cover hundreds of thousands of kilometres without need for a new head gasket
16-07-2007, 01:31 PM | #8 | |||
16-07-2007, 01:31 PM | #9 | ||
I think you'd find its much cheaper and easier to just replace the head gasket, with the right tools wont take more then a couple of hours. If you can't do it yourself I still think you'd get charged less for replacing a gasket then the whole motor. I'd be guessing labour wouldn't be much different either way but a gasket is alot cheaper then a decent motor.
16-07-2007, 01:36 PM | #10 | |||
16-07-2007, 01:45 PM | #11 | ||||
Kick out tha Jams
The gasket itsellf is worth no more then a bag of potato chips (okay a little bit more) and installing it is more or less a matter of undoing a few bolts and then tightening them back up once its on. Invest in a gregories manual and a set of sockets and do it yourself. just because its a big problem to have, doesnt make it an overly difficult (or expensive) one to fix. and for that sort of money, you can afford to take the whole week off work to do it (even though you'll probably just get it done on a saturday morning/arvo anyway - that leaves you the rest of the week to run a muck). Those manuals pretty much describe everything well enough for a 3 year old to strip the whole motor down and rebuild it themselves If there charging 700-1200 just to replace the gasket, imagine what they'll stab you for for the whole engine, so as stated above, unless the engines pretty dead other than the head gasket, just do the gasket! Quote:
$416.80.......All that cash came from a new (used) car. Check your back seats! |
16-07-2007, 02:04 PM | #12 | |||
16-07-2007, 02:35 PM | #13 | ||
Spin 'em Habib !
A Reco 100k is AU motor is Cheap at 330bucks , I just bought the one off Ebay ..
AU2PWR |
16-07-2007, 07:06 PM | #14 | ||
a change over head is another option if the valve gear is gettin tired, does any one how much a change over is?
16-07-2007, 09:06 PM | #15 | ||
well mate im a mechanic and if i was you i would go that motor of ebay....buy the time you get your head machined etc (if it is repairable maybe have a crack etc it) it will cost you more than the engine...and if you do get ya head fixed youl end up with i 240.000km eng with a new head...youd be better of going with the engine...id find out if they give warranty with engine but hey....just my 2cents anyway...hopefully it all works out for ya....
16-07-2007, 09:09 PM | #16 | ||
the mob on ebay at logan city give 3 months warranty
