06-09-2007, 07:56 PM | #1 | ||
Hi
My boot lid won't open, I can hear the actuator trying to open it, so it's not electrical. I can't get into the boot because it is dual fuel, but I've taken a speaker out and have found the manual boot release but that seems to be stuck also. Any ideas? Big crow bar or oxy? |
06-09-2007, 07:59 PM | #2 | ||
Sly like a G6
Has it rained near you lately? My tailgate always sticks after rain and needs a big pull to open. Maybe get a helper to press your button while you pull on the bootlid.
The Frankenfalcon... AU1.5 Wagon, BA brakes, AU2 booster, BA2 XR6T engine, stock from airbox to turbo, 8psi/98 octane tune 240RWKW, BF XR6T cat, quiet 3" zorst, Pex BSO660 & BSO439 mufflers, 84 db, built BTR box, 3.08 LSD, Emer SVI LPG, AU1 XR8 alloys, Momo wheel, JVC KDR746BT head unit, Aerpro steering wheel control wiring. Sleeper, anyone? |
06-09-2007, 08:25 PM | #3 | ||
Yeah I tried that, no luck. It's as if the latch is jammed,if it wasn't for the lpg tank I could probably get in with a screwdriver or something and force it, can't do much through the speaker hole though.
06-09-2007, 08:59 PM | #4 | ||
www.TUFFCARPARTS.com
I'm still investigating, but I think I know why mine's stuck...
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
06-09-2007, 10:37 PM | #5 | ||
AULTD
Thats a shame to see a well looked after car have that happen.
I suppose it is one way to get into the boot though!!!! How did you end up with a white piece across the boot instead of the red, have you been raiding LTD's?? |
07-09-2007, 09:43 AM | #6 | |||
07-09-2007, 10:57 AM | #7 | ||
Just keep yanking the manual release while someone pushes down and pulls up on the boot lid (ussing alot of force). After 10 minutes if still no joy your oxy idea sounds like the next path of attack
07-09-2007, 11:09 AM | #8 | ||
lpg = big boom!
it will be a cable loose in the auto release,
hop in the boot via rear seats.. and there is a cable that joints the lock to the solenoid. yank the cable
BF Futura Dedicated E-GAS w/Ghia bling Project: 86 ZL Fairlane, Red, Sunroof, 310,000KM |
07-09-2007, 11:40 AM | #9 | ||
14.915 @ 151 KPH
ummm. i hate to put a spanner in the works but i wouldnt be using an oxy near AN LPG TANK : . a crowbar sounds better
:evil3: 96 EF2 Futura I6 Auto :evil3: EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's : , XR6T Snorkle/Fram Filter, 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD, 5% Tint, Sony Head Unit/ 6 1/2 Inch 190w Speaker's : 14.915 @ 151 kph 60' 2.254 : |
07-09-2007, 11:49 AM | #10 | ||
this is locking the stable door after the horse has bolted i know but the factory dual fule cars had a longer emergency release cable. it runs to a spot just behind the seat. I just bought one for mine but i'm yet to fit it. only cost about $40
07-09-2007, 12:19 PM | #11 | |||
07-09-2007, 04:36 PM | #12 | ||
CRE.87V
hey mate mine did this a few weeks ago...wen i popped the boot i had to like push down, not to shut and then pulled up...opened then....then i sprayed the whole rubber with silican spray...never had a problem since
08-09-2007, 08:18 PM | #13 | ||
Finally managed to get the boot open, here's how I did it in case this happens to anyone else out there.
I pulled both speakers out, got my daughter to point a camcorder on Night shot mode through one speaker hole so I could see what I was doing on a 14 inch TV in the middle of the back seat, that made it a lot easier! after having no luck with the cable i used a long flat bladed screw driver with a 10mm socket on the end to undo the two nuts holding the latch mechanism to the boot lid, then used a broom handle with a solid hook on the end to wrench the latch off. Ripped open the boot lid, luckily the plug disconnected without damage, the cable was out of position anyway because of my previous efforts. a long arm required! I was up to the armpit and my head was wedged sideways up on the parcel shelf. I found corrugated cardboard jamming up the latch, pulled it all out, works a treat now! I also extended the boot release cable and brought it over the lpg tank although it would not have made a difference in this case, it could be handy in future. |
08-09-2007, 08:25 PM | #14 | ||
Fiat POWAAH!
i'm loving the dedication and ingenuity!
MacGyver has nothing on you |
08-09-2007, 09:56 PM | #15 | ||
Great effort mate! By that stage I think I'd be out there with the crowbar!
09-09-2007, 10:38 PM | #16 | ||
Blue ~oval~ Blooded!!!
had a similar trouble with mine peice of carboard got caught in the latch. had to unload 4 people's worth of luggage through the rear seats, coz my mate reefed on the manual release and frigged it. had to crawl in and un-bolt the latch.
thankfully mine is petrol only though.
Give me fuel, give me fire! 50th Anniv G6E Turbo in Sensation Cobalt blue 94 ED XR8 Sprint- resto/ project
10-09-2007, 12:04 AM | #17 | ||
Plastic bags and airport luggage tags are good for jamming in there too
