why does the fuel injection fuse keep blowing and how can i fix this? drive down the road and it blows, put a new 1 in, get up the road and blows again
Over Thinker
the fault would be in one of these
faulty sensor-air flow meter/Throttle position sensor/o2 sensor the injectors the engine management computer there should be a diagnostic plug where you might be able to get a diagnostic reading before the fuse blows or you have to unplug each sensor seperatly and test and connect each unit until the fuse blows then you have the answer .you can buy a dick smith or tandy LED tester or a volt meter a gregories repair manual is helpfull if you dont have one most libraries can help you there
My car goes Brumm Brumm |
