Old 09-12-2008, 03:03 PM   #1
mr_xr8
Capri GT/TS50/GTR
mr_xr8's Avatar
Default sway bar hitting lower control arm
anyone have a problem with the swaybar moving and hitting the lover control arm?
it has only moved in the last few days.
the car has had the AUII fron end swap done to fit bf brakes.
at the time a pedders sway bar was used as it was cheaper then a new one from ford.
the sway bar has moved all the way to the passanger side and the drivers side lower contol arm is resing on the mount.
any ideas what caused it and how to fix it?
R32 GTR Rebuild
TS50 Build
mr_xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2008, 03:26 PM   #2
MaTTe
It'll be similar to the whiteline ones.. they mount the bars differently, so the force is delt with differently and shifts the bar.
Whiteline make a bush that sits up against the Ubolts on the crossmember to stop the bar shifting side to side. I'm not sure which forums it was on, but someone has taken photos of it.. Call whiteline and tell them of your problem and they'll give you a part number, from memory it wasn't expensive. You'll need one for each side.
Shed cleanout.. Pictures and prices here
Dynamat type product Group Buy Here(Round 2)
MaTTe is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2008, 03:50 PM   #3
mr_xr8
Capri GT/TS50/GTR
mr_xr8's Avatar
just for everyones ref for a 30mm sway bar the whiteline part number is w0450-30
thanks for the help all fixed now
R32 GTR Rebuild
TS50 Build
