Hi everyone, new to the sight and new to fords. I purchased a used ford focus LR 2002 manual and two days after purchase driving around the hand brake light on the dash comes on and off randomly. Is this a simple fix or am I going to have serious drama???? Also anything else i should be keeping an eye out for???
Thanks In Advance |
EuroFordClub
Could be the handbrake earth wire shorting out on something? That's the only thing I can think of. Does it flick on/off? Or does it come on and stay on, then go off all of a sudden?
'08 Black Ford Focus LT CL Hatch
Far from stock... --- SOLD ![]() Now riding a 2009 Kawasaki Ninja 250R ![]() |
It flickers on and off??? Anything i can do myself or have to take to a mechanic?
EuroFordClub
I'd check the hand brake ground cable and make sure it isn't shorting out on anything. Not sure where it's grounded to in the LR. If you can, take the cover off the handbrake and see if you can follow where the ground cable (most likely a black wire) runs to the chassis. Check the wire to make sure it isn't worn anywhere along the line, or that the connection onto the chassis isn't loose at all.
Zoom Zoom
Sean's car (my old car) does this from time to time for no aparrent reason. I believe Eddie is also having something similar...
Hmmmm
2012 Mazda3 MPS
Lil Henry
doesnt the hangbrake light also act as a brake failure warning light as well?
Motorsport Guru
Zetec's spot on. I'm still encountering this weird problem but there's absolutely no problem with the performance of the brakes. I've got ABS BTW. The latest "solution" to finding the problem is that an Auto Electrician is going to come to the Dealer and they say the seats need to come out for them to access things so Gerry will need to stay overnight and I'll be suggesting that they check the handbrake ground cable.
I'll keep you posted as to when I've got it fixed.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System. Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle. Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust. Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus. |
yum
Could also be a dead handbrake switch.
2005 LS Focus LX
Nov05 | Manual | Black Sapphire 250,000kms. |
2007 Ford Focus Zetec
If your brake fluid is low, your hand brake light might flash or stay on.
Might want to check this ![]() |
mine does it occasionally, but only when going around corners, quite fast with a few bumps... scared the crap outa me when i first saw it(well a glimpse really)... thought the back end was going to come around....
Zoom Zoom
Sean's car is identical, only around corners.
Right, I'm talking to the engineers tomorrow. Let me get back to you all.
2012 Mazda3 MPS
#12 | ||
Zoom Zoom
I posted on FFOC http://www.ffoc.co.uk/modules.php?na...topic&t=203787
Searching now for more info...
2012 Mazda3 MPS
#13 | ||
Motorsport Guru
Same problem as discussed in previous posts. Brake/ABS Lights flickers on and off and it's been confirmed today it's an Instrument Cluster Failure. Common problem I'm afraid.
#14 | ||
yum
Does it cause cruise control to shut off?
2005 LS Focus LX
#15 | ||
Motorsport Guru
Quote: "Does it cause cruise control to shut off?"
No, that's working as per normal. I've been quoted $1,080 for a new Instrument Cluster btw.
#16 | ||
yum
They state exactly the failure in the cluster? I'd imagine it would be a 5c component like a capacitor.
2005 LS Focus LX
#17 | ||
AFF Post NAZI
dont bother getting a new cluster not worth the money and its only the light. the car actually doesnt register that the HB is up so it doesnt effect TC or CC. trust me i tried
#18 | ||
Zoom Zoom
If you need to, just Ebay or crash parts. No need to spend $1,000 on a bloody cluster
2012 Mazda3 MPS
#19 | ||
Motorsport Guru
Quote: "No need to spend $1K on a bloody cluster." You're dead right there. Besides I've now actually been left another "present" which I suspect is courtesy of someone in a Ford Service Dept.
#20 | ||
Hi guys, sorry to drag up an old thread - my wife has a 2000 laser with what appears to be the same problem - we will be driving along, then the brake warning light comes on - then stays on for maybe 2 or 3 minutes, then goes off for the rest of the time driving.
Very intermittent, not flashing or flickering - when it comes on it stays on for a little while - not whilst braking or anything. It did it to me the other day drivin down the freeway - no stop or start etc... Would the fault be the same as a focus - in the instrument cluster, or has anyone had this prob with a laser? Brake fluid levels are all good, brakes feel great. Cheers Randel
Daily Driver - FG GS Ute Toys - 351 XY Falcon and FG GT |
#21 | ||
Motorsport Guru
Randel, Sorry I can't personally answer your question re: your Laser. May I suggest you post your Question over in the Laser Section of the Forums and that may help you further. Does sound similar to what I'm experiencing though.
