Old 02-07-2009, 03:12 PM   #1
V8 EF Fairmont
Default Coil Packs and Idle
A few weeks ago the missus got a new battery installed in the XR8. Since that time the idle has been really hit and miss in that it idles fine most of the time, however when you put it in neutral or park it will stall 80% of the time or idle really rough. Starting in neutral or park it idles fine. Just come back from the garage and the computer had an error code for the coil packs. Cleared the error and car went fine for a while then started playing up again. Does this mean I'm up for a new set of coils or could there be something else the problem? Is there any way in which I can rejuvinate the coils? I eventually want to put s decent set in, but can't afford to at the moment.
V8 EF Fairmont is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2009, 06:38 AM   #2
V8 EF Fairmont
Also does anyone know if the AU and EF coil packs are the same?
Old 03-07-2009, 08:32 AM   #3
whiskers
gone fishing
whiskers's Avatar
I'm pretty sure that once the coil pack/s are gone that's it with them, as with the codes, not sure about that.
But i would hazard a guess that if the codes were cleared and the problem went away and then came back, I sure would be looking at the coils being stuffed and need replacing.
Whiskers
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2009, 10:58 AM   #4
BillC
Look at IAC valve first and give that a good clean. There are about 100 posts in this forum that tells you how to do that. More than likely thats your problem.
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2009, 11:20 AM   #5
RG
Back to Le Frenchy
RG's Avatar
Not if a coil pack error code is coming up.
Time for new coil packs, they only have a lifespan of 80-100k anyway. MSD ones are cheaper and better, and no EF ones aren't the same as the EF ran a distributor.
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2009, 02:57 PM   #6
V8 EF Fairmont
Yeah was my first port of call as I had this issue with previous models, however didn't fix the problem. Interesting that the issue didn't come about till the missus got the battery replaced. Hope they didn't fry anything....
Got some 2nd hand coils to throw in so hopefully that makes a difference. Over $600 for new ones!
Old 03-07-2009, 02:59 PM   #7
RG
Back to Le Frenchy
RG's Avatar
$140 each for the MSD ones.
Old 03-07-2009, 03:22 PM   #8
blueoval
Critical Thinker
blueoval's Avatar
I paid $100 on ebay for a brand new OEM unit.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 03-07-2009, 03:23 PM   #9
RG
Back to Le Frenchy
RG's Avatar
6's and 8's are different mate.
Old 03-07-2009, 03:44 PM   #10
blueoval
Critical Thinker
blueoval's Avatar
oh ok. I'll go now :
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 05-07-2009, 09:30 PM   #11
saber
Umm, I'm pretty sure the EF ran a coil pack, they switched back to a dizzy in the EL, then back to a coil pack for the AU.
But as RG said, get yourself some MSD coils. Your going to get bent over if you go to ford and buy the OEM part.
saber is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2009, 10:33 PM   #12
bodes-sh
i6 yes, v8 no
bodes-sh is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2009, 08:31 AM   #13
RG
Back to Le Frenchy
RG's Avatar
This is for an XR8, the AU was the first V8 to run coil packs in place of the distributor.
You are correct for the I6 however.
Old 06-07-2009, 10:51 AM   #14
DJM83
Barra Turbo > V8
DJM83's Avatar
I know its different but have you tried an ECU reset? Same thing happened in my TE had the battery replaced, stalled when in neutral and sometimes had to drive with 2 feet aswell.
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
Old 07-07-2009, 11:13 AM   #15
TX3VIL
where do i get some MSD packs from in melbourne and what's the part number for them? Do i need and specific leads to go with them? prefer to get msd leads too i guess. do u use 8mm or 10mm?
TX3VIL is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2009, 11:23 AM   #16
RG
Back to Le Frenchy
RG's Avatar
Leads can be had from Dave at A1 Performance, PM member BOTTLEDUP.
Coil packs can be had from anyone who uses Rocket to get their parts, there were a few sets on eBay recently so check there first as they were cheap. The part number is MSD8241 and obviously you need 2.
Old 07-07-2009, 12:03 PM   #17
GK
Walking with God
GK's Avatar
It will cost you nothing to do this and it's worth a try. Only 10 minutes work.
Resetting of AU ECU
http://www.fordforums.com.au/showpos...9&postcount=85
I agree it's probably the coil packs, especially with the code occurring, however, resetting the computer and cleaning the IAC/ISC valve will not hurt you, is a good thing to do every 3 or so months and does help the car to go better. You never know, it may sort the problem!
Give the TB a cleaning whilst you're at it.
Cleaning ISC Valve
http://www.fordforums.com.au/showpos...9&postcount=43
Cleaning Throttle Body
http://www.fordforums.com.au/showpos...2&postcount=48
All the best with it.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 08-07-2009, 06:50 AM   #18
V8 EF Fairmont
Yeah resetting the ECU worked for about 5 minutes, then it obviously relearnt the coil packs are stuffed. Got some coil packs to chuck in it over the next few days.
Also cleaned the ISC valve, no change. And the MAF, no change either.
Must be the coil packs...
Old 08-07-2009, 10:59 AM   #19
GK
Walking with God
GK's Avatar
It's good that you've followed a process, rather than just throwing money at what you may think is the problem. I hope the coil packs get it all sorted nicely.
All the very best with it.
GK
Now gone!
On LPG
Old 08-07-2009, 04:23 PM   #20
V8 EF Fairmont
Start with the cheapest and easiest, and work you way up through the dollars and difficulty from there!
