17-08-2009, 05:17 PM | #1 | ||
OzEcruisers PRESIDENT
Searching Google I have found that the part number for the AU Injectors is:-
Bosch 0280 155 844 And they Flow 20lbs/hr They also have 4 pin hole which spray the fuel Also i read somewhere else that the Bosch 0280 155 844 flow 14.3lbs/hr And I have no idea what the Fuel Regs for the AU's are rated at - can anyone help me out? Is there a difference between the XR Models and the Std I6 models?
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
17-08-2009, 05:21 PM | #2 | ||
Non XR6 at idle is 225kpa
XR6 is 250kpa With reg vac hose dissconnected its 275kpa non XR6 XR6 " "300kpa |
17-08-2009, 06:32 PM | #3 | ||
Sweet - thanks for that
SO whats the flow of the XR's Injectors - I assume they have more flow than the Std I6
17-08-2009, 06:43 PM | #4 | ||
Pretty sure they are the same,they have a slightly larger flowing fuel pump though
17-08-2009, 07:43 PM | #5 | ||
Thanks Gilmore
On another forum The EA thru EL ran 0280 150 790 --18.15lbs/hr 1988-1998 The AU ran 0280 155 844--14.3lbs/hr 1998-2002 That cant be right.................arrrrrrgggggggg!!
19-08-2009, 10:08 AM | #6 | ||
FYI Hmm smaller injector flow for an AU
Au Injectors Part Number 0-280-155-844 Lbs/hr 14.3 Cc/min 150.3 Grams/min 108.1 Feed EV6 EF-EL Injectors Part Number 0-280-150-736 Lbs/hr 18.25 Cc min 191.8 Grams/min 138 Feed EV1 EF-EL Injectors Part Number 0-280-150-790 Lbs/hr 18.17 Cc min 191 Grams/min 137.4 Feed EV1
19-08-2009, 01:03 PM | #7 | ||
Bugger than info was wrong
Here is the correct info 0 280 155 844 - 150.2 g/min - Tested resistance was 14.5ohms which are EV6's 0 280 150 790 - 149.7 g/min - Tested resistance was 15.9ohms which are EV1's Here is the linky to the Bosch Catalogue http://www.bosch.com.au/content/lang...linjectors.pdf
