Old 23-01-2010, 10:17 PM   #1
LANKY 1
Are the Supercars on yet?
LANKY 1's Avatar
Default Park Brake question
I went into Ford yesterday to get a new cable for the handbrake. i just wanted the short cable from the lever to where it connects under the seat under the ute. the guy at parts said the cable comes with the whole lever as well and they want $300+!!! is this right? Ute is 2001 with manual,
The service department also said there is adjustment in the rear brakes. i might have to look at that cos i have run out of adjustment at the lever.
A Ford win is a good win!
V8 dreamteam
1st: 2012, 2021
2nd: 2015, 2016, 2020, 2022, 2023, 2024
3rd: 2014, 2018, 2019
LANKY 1 is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2010, 10:26 PM   #2
xrford
WAGONE
xrford's Avatar
from memory the handbrake cable is a 2 piece one where the cable runs from the handbrake itself through the floor then connects with the other piece to the diff.
Yeah pretty sure there is an adjustment point under the car as well so may just need to back it off at the handbrake and tension it up from under the car, just not too much tho.
xrford is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2010, 10:28 PM   #3
LANKY 1
LANKY 1's Avatar
yeah. from what ive seen it's 2 pieces. but when i went to get 1 piece ford said i had to buy the whole hand brake lever aswell? seems a little weird
V8 dreamteam
1st: 2012, 2021
Old 23-01-2010, 11:50 PM   #4
Whoosha
AU DIE HARD
Whoosha's Avatar
Have you adjusted it at the disc at all ?
have a look through here for some tips
http://www.fordforums.com.au/showthread.php?t=11244844
Originally Posted by Riksta
Old 23-01-2010, 11:55 PM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Uh, why do you want a new handbrake cable?
Have you adjusted the shoes?
Have you adjusted the 10mm bolt on the side of the handbrake lever itself?
Old 25-01-2010, 01:46 PM   #6
LANKY 1
LANKY 1's Avatar
the thread on the bolt next to the lever has been stripped so was gonna replace it.
adjusting the shoes was my next plan as i have run out of adjustment at the lever
V8 dreamteam
1st: 2012, 2021
Old 25-01-2010, 02:09 PM   #7
LANKY 1
LANKY 1's Avatar
Cheers, found ur tutorial on the park brake. I'll give that a go
V8 dreamteam
1st: 2012, 2021
