Old 04-06-2010, 07:09 PM   #1
JMO
JMO's Avatar
Default replacing seat belt
I have a replacement seat belt that I want to install (rear passenger) but there is only about half a metre of slack on it and it won't let anymore belt out. Have I stuffed up by letting too much go in or is there a way to get it back out? Will it come good after the retractor is bolted into position?
Cheers.
JMO is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2010, 07:17 PM   #2
adrian k
adrian
adrian k's Avatar
its cactus mate
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2010, 07:40 PM   #3
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
make sure its upright and push a touch more in, it will still release and come good.
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2010, 09:28 PM   #4
adrian k
adrian
adrian k's Avatar
Cheers.
sorry, re-read your post, it will probably come right mate.
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
Old 04-06-2010, 10:08 PM   #5
JMO
JMO's Avatar
Thanks guys
So by upright you mean bolt it up and then let some in? I don't want to let any more in now while it's loose and I'm not sure which way is up incase i stuff it up completely :P
Old 05-06-2010, 02:12 AM   #6
Eleanor
Eleanor's Avatar
They'll only work when on the level like when bolted in the car. I have to replace two of mine shortly and haven't pulled seats and trim out yet to have a look but I thought there'd only be one way up, or one way to bolt them in?
G'day I'm Paul
My AU2
Eleanor is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2010, 02:14 AM   #7
bartsau
bartsau's Avatar
did this on one i had from a wrecked au and lost all the slack, put it back in the car and no problems. Must be something to do with the angle or pressure on a particular point i think.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
Old 05-06-2010, 05:03 AM   #8
JMO
JMO's Avatar
Okay. I'll resist trying to fix it until I've got it back in the car. I'll let you know how it goes
Old 05-06-2010, 09:19 AM   #9
Eleanor
Eleanor's Avatar
Actually can anyone tell me - is it a particular Torx bit or a regular bolt on the seatbelt mounts? I haven't had a chance to have a look yet or buy a manual either.
G'day I'm Paul
My AU2
Old 05-06-2010, 09:27 AM   #10
DW260
DW260's Avatar
I replaced one only a couple of weeks ago Front driver) and I needed to use a Torx bit. Bit size reads - T50.
I had the slack problem as well, but once it was in, it all came good.
FPV GS Ute #370/Brembo brakes
DW260 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2010, 10:08 AM   #11
T3man
T3man's Avatar
Once it is bolted in place it will be fine. Unless of course it's fooked.
