Old 17-11-2010, 06:30 PM   #1
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
Default Replacement XR8 Balancer????
Could somebody in the know please tell me if this is the correct steel replacement balancer for the AU 220 engine? 6.4" 50oz counterweighted outer ring. I hope the link works.
Thanks.
-Craig
http://www.rocketindustries.com.au/d...rtno=PB1084-SS
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2010, 06:46 PM   #2
crakrz
T3 TE50 Blueprint
A bit more research tells me I need the one with the inbuilt crank trigger pulley- part no. PB1463-ST.
Do the AU3 XR8 ones normally give trouble?
Old 17-11-2010, 08:03 PM   #3
philstoj
philstoj's Avatar
Yep, they spin the outer on the rubber and vibrate, very common thing.
Powerbond make a good one for reasonable $$$, no point getting an orig one again.
They have the main pulley and the crank trigger sprocket built in, so only one bolt to put on and they are 50 oz balance, im sure the part number you posted is the powerbond one.
philstoj is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2010, 01:28 AM   #4
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Yes thats the one i have, still got the box PB1463-ST.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2010, 08:06 AM   #5
crakrz
T3 TE50 Blueprint
Thanks Fellas, much appreciated.
Old 21-11-2010, 09:14 AM   #6
DaveTE
Back in black
DaveTE's Avatar
What symtoms am I look for?? I have a small vibration at low revs when stopped or just rolling in Drive. Don't seem to notice it when I have a the pedal down.
Black Mac TE50 S3 NO: 106
Little Mac AU S2 XR8
Bite the snake before it bites you!
______________
_.__ /________...\
_.._(___\\___//___)
.._..(O...\____/...O)
DaveTE is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2010, 10:33 AM   #7
SSD-85
I replaced the one in mine, most vibration occurs at 1100-1300rpm. Regardless of engine load. Once you change it, it will feel like a brand new car. In combination with leads & SPs its even better.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2010, 01:20 PM   #8
sleeper393
sleeper393's Avatar
ross tuffbond balancers are far superior to powerbond. the fellow whom runs powerbond borrowed ??????? tuffbond designs !!!!!!, i know this as i worked for tuffbond in its infancy
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak!
AU SERIES 3 LIQUID SILVER
BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS
123.4 GROUND TEARING RWKW'S , LOL
sleeper393 is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2010, 09:12 AM   #9
greenguzzler
V8 AU Fairlane
I get the same terrible vibration at those rpm's and the local Ford mechanics looked at the harmonic balancer and said it wasnt that. Anyone else have any ideas before i take it to somewhere else to get the balancer done?
Thanks Pete.
greenguzzler is offline   Reply With Quote Multi-Quote with this Post
Old 23-11-2010, 01:37 PM   #10
sd1800
I have a slight vibration at about 1200rpm and again at about 2100rpm.
Have tried to check that balancer lines up at TDC cylinder 1 but I find the ol' screwdriver down spark plug hole trick very hard, as it's hard to determine when the piston is right up the very top before it drops again.
Is there any other way of checking if the balancer has spun?
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6.
Now......
2012 FG MK2 XR6 Turbo
- Manual & Luxury Pack
- 302rwkw
2019 Escape St-Line
sd1800 is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2010, 04:47 PM   #11
Boza
Boza's Avatar
there are balancers on ebay for 150 bucks at the moment
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 26-11-2010, 07:27 PM   #12
philstoj
philstoj's Avatar
Yes but they arent for AU V8, the AU V8 ones are $199.
Old 26-11-2010, 07:39 PM   #13
Dingo
Ford T3 Partsologist
Dingo's Avatar
we can do Brand New Powerbond HB1463-N $205.00 or PB1463-ST $295.00 plus postage
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2011, 08:52 PM   #14
sd1800
Are these Nuline ones OK? Or are they cheap rubbish?
Now......
- 302rwkw
2019 Escape St-Line
Old 04-01-2011, 04:55 PM   #15
sleeper393
sleeper393's Avatar
Thumbs up
go ross tuffbond.
http://www.rosstuffbond.com.au/
