05-10-2011, 01:43 PM | #1 | ||
Hey guys,
As some of you may or may not know i currently race an AU off Road. It still is an open Spinner Diff, and was looking into either fitting a mini Spool, or LSD. Im leaning towards a mini spool, as it seems to be a hell of a lot cheaper, for the same result, but saw a friend who had a mini spool in on a 25 spline commodore diff, snap a couple of axles. Would a 28 spline be stronger? I dont want to be constantly swapping over axles. Thanks
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box| |
05-10-2011, 04:16 PM | #2 | ||
RIP...
If it's used only off road, a mini spool would be my choice.
Mini spools break stuff on the road because there's no give around corners. Big sticky tyres will snap axles. They're also pretty dangerous in the wet. I wouldn't use a mini spool on the road, so if the car is dual purpose, then an LSD is your only choice IMO.
. Oval Everywhere... |
05-10-2011, 08:31 PM | #3 | |||
You may need to adjust your wheel alignment settings too after you install a mini spool. On road mini spools accelerate trailing arm bush wear, Can twist axles then sheer them off, defectable, can be dangerous in the wet and in car parks people look at you funny as you turn in.
AU XLS. |
06-10-2011, 11:02 AM | #4 | ||
Yeah we have one event a year that is tarmac...
Time to look for a cheap LSD... Im guessing EF/EL LSD wont fit into an AU? just seem alot more common than the AU ones. Is $500 a good price?
06-10-2011, 11:16 AM | #5 | ||
Critical Thinker
Are you looking for an LSD centre or entire diff?
As long as the diff is live rear and not IRS, its possible to fit one from an EL into an AU. But don't quote me on that.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
06-10-2011, 12:59 PM | #6 | ||
Interesting... Will have to do some research on that... Am i right, to tell the difference, when you bounce the car, IRS will not move with the car, but live axle will?
06-10-2011, 01:56 PM | #7 | ||
Getting By!?
spool if always off road imo
06-10-2011, 02:20 PM | #8 | |||
Critical Thinker
Live rear axle IRS rear axle I still dont know about the centers being interchangeable.
06-10-2011, 03:18 PM | #9 | ||
meh.
EF/EL Diff will fit, but you will have the offset change, so running pre-au offset rims will be needed...
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
06-10-2011, 03:30 PM | #10 | ||
Critical Thinker
Is there a difference with offset for the rear? I thought the offset was nil on EL to AU diffs. Only the front had the different offset?
06-10-2011, 03:36 PM | #11 | ||
meh.
Nope, rears had a different offset, which is why many people with E-Series who are running a Cebco/RBS front twin piston brake upgrade kit, generally tend to upgrade to an AU diff to give them AU onwards offset all around...
06-10-2011, 03:48 PM | #12 | ||
Critical Thinker
Ok no worries. Cheers for clearing that up
06-10-2011, 09:05 PM | #13 | |||
[SIGPIC][/SIGPIC]
06-10-2011, 09:10 PM | #14 | |||
06-10-2011, 10:39 PM | #15 | ||
how much did you pay for once of them?
