Old 13-10-2011, 10:24 PM   #1
Vincenzo
Vincenzo's Avatar
Default What's 100kg worth hp / kw
Point in question
I have an AU XR6 111 rated at 168kw and weighing in at 1470kg
My Ex just bought an FG XR6 rated at 190kw and weighing in at 1760kg
Firstly, considering the AU is 290 kg lighter than the FG how much is 100kg weight saving worth in terms of hp / kw
Secondly, I hope to shortly do some modifications to the AU gaining about 50kw at the flywheel (so I have been informed) - so what increase can I expect at the wheels
(cai, pacemaker 4480, ballistic 100cpsi cat, bpr perf 98 ecu upgrade and 2 1/2" sports system)
Vincenzo is offline   Reply With Quote Multi-Quote with this Post
Old 13-10-2011, 10:27 PM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: What's 100kg worth hp / kw
on the quarter mile, losing 100kg off the cars weight is worth 1/10 of a second
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2011, 08:36 AM   #3
Vincenzo
Vincenzo's Avatar
Can you equate a tenth of a second gain on the quarter mile in terms of horsepower needed?
Old 14-10-2011, 08:54 AM   #4
V8XTasy
the AU has a power to weight of 114kw/tonne
the FG has a power to weight of 107kw/tonne
so would need 200kw to make up for the extra 290kg, all other things being equal.
Falcon BA XT 5.4 V8 3v
V8XTasy is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2011, 09:24 AM   #5
StrikeTwiceXR6
My experience is this: I had a BF that had full exhaust, underdrive pulley, and dynotune (173rwkw) and still it felt like it was only marginally ahead of my wifes FG. The FG Barra runs 195kw on the "bottom of the creek" quality fuel and runs at over 200kw on simple 95 octane. On 98 octane, the FG will run better once again (rumoured to produce 210kw and 420nm). The FG is no slouch despite it's weight. Not trying to start a petty power war here either. Hope this helps.
StrikeTwiceXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2011, 10:26 AM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Three things are wrong with this thread.
1. FG's aren't 190kw, they are 200kw and 195 when the knock sensors kick in.
2. How is your AUIII 1470kg? Unless you've done some serious weight saving modifications, it'd weigh at least 100kg more than that.
3. Those mods aren't going to see 50kw at the flywheel. Maybe 50hp, if you're lucky.
Old 14-10-2011, 10:47 AM   #7
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
My goal with my AU ute I had at the time was stock engine power at the wheels. I ended up with 147rwkw untuned.
Mind you the time prior I had run it up on the dyno "tuned" and with mixer ring gas it ran up 112rwkw. So blocking off the chip I had at the time and removing the mixer ring netted me 35rwkw.
I think if I had've revised my air intake and got the car flashed I would've seen 157rwkw
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2011, 10:51 AM   #8
Mr Hardware
Also, just remember, unless its super easy, removing sprung weight can turn into really bad value really quickly. Reducing unsprung weight is where its at.
Old 14-10-2011, 10:57 AM   #9
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
generally, racers equate 100 lbs with 1 tenth down the 1/4
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 14-10-2011, 11:40 AM   #10
Day-mow
rexnet
Day-mow's Avatar
so 50 lbs with 1/10th down the 1/8th?
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 14-10-2011, 01:04 PM   #11
Mr Hardware
^ someone failed maths
Old 14-10-2011, 01:30 PM   #12
trbo 6
I have a drag time spreadsheet that I use that is fairly accurate.
Using the stock flywheel kw figures above i get this:
AU XR6 = 14.963 @ 95.67mph or 154km/h
FG XR6 = 15.250 @ 93.87mph or 151km/h
If I add 100kg to the AU and FG time difference is:
AU XR6 = 0.332s
FG XR6 = 0.283s
So it's about 0.3s per 100kg
trbo 6 is offline   Reply With Quote Multi-Quote with this Post
Old 15-10-2011, 12:18 AM   #13
superroo
You can't stop the signal
superroo's Avatar
Double check that weight on the au and don't believe what the rego sticker says.
My rego sticker list's the ute at high 14xx kg, yet the weigh bridge I crossed, it came in at 1790ish kg.
And there's not 300kg of crap in there either.
Old 15-10-2011, 03:58 AM   #14
Vincenzo
Vincenzo's Avatar
Talking Re: What's 100kg worth hp / kw
[QUOTE=Vincenzo]Point in question
Firstly, considering the AU is 290 kg lighter than the FG ]
All right - according to Ford's own paperwork the AU is 164kw / 1530kg
and the FG is 195kw / 1710 kg - my apologies to those I annoyed - I was quoting other sources.
Still 180 kg difference
Old 15-10-2011, 04:19 AM   #15
Vincenzo
Vincenzo's Avatar
There is nothing wrong with this thread - I am asking questions and learning
1. Fixed in the above reply
2. As above and will visit weigh station tomorrow to verify
3. As for 50kw / 50hp I was simply repeating what I was informed by a supposedly knowledgeable person - though he was trying to sell me a supercharger at the time
Old 15-10-2011, 04:21 AM   #16
Vincenzo
Vincenzo's Avatar
Thankyou - this is what I am looking for.
Old 17-10-2011, 11:25 AM   #17
Mr Hardware
but you've also got to remember that sometimes weight can be an advantage. removing your spare tyre to save 20kg might end up losing you time because of the weight over the rear wheels changing leading to less traction.
Old 17-10-2011, 11:45 AM   #18
mik
mik's Avatar
there are also gears to consider, even a modded au will have to work hard to get past the extra cog/s in the later models, taking my mates bf2 zf equipped for a squirt, it made my s2 au seem like a slug, current models really have a serious turn of speed even n/a.
Old 17-10-2011, 11:49 AM   #19
DJM83
Barra Turbo > V8
DJM83's Avatar
Gee shoot someone down for asking a question, theres nothing wrong with gaining some knowledge, your bound to get some wrong info before getting the right stuff.
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 19-10-2011, 10:17 AM   #20
Mr Hardware
OP sorry that being frank came across as being rude
