21-11-2005, 11:42 AM | #1 | ||
BASS ON BOARD!
Hi fellas just need to know if this is a common problem,
I have finished the T5 conversion and have wired up the resistors and the linear pot to the auto ECU. now it stalls when pulling up to a stop. the revs will fall and it will become realy rough.....then stops. i know drive is ment to be 2.5V (in the pot) but my car wouldnt idle so i had to put it to 3.9v for it to be happy. any ideas? Would a after market management system or a Chiptorque chip fix this? any help you be great thanks guys
Nothing interesting to put here. |
21-11-2005, 11:51 AM | #2 | ||
need more boost
I have yet wire up anything on mine other than the speedo wires and earthing the starter relay... and it runs fine :P We'll have to wait and see what happens when i cam+extractors it...
'94 ED Falcon GLi Suspended by: kings, koni, pedders Rolls on: 17" AJR Director's Stops due to: bendix, DBA Shifter connected to: T5 manual Power from: ??? Interior: velour and woodgrain Cost: stuff all :P |
21-11-2005, 12:13 PM | #3 | ||
BASS ON BOARD!
Yeah mine runs fine as well it will sitt all day and idle happy!
just for example pulling up to stop as a set of lights and pop it back to 2nd.....then a few meters from the stop line you put the clutch in and thats when it gets upset and stalls. so i think i will speak with chiptorque or JMM to see which is the best way to go to fix the issue.
21-11-2005, 12:26 PM | #4 | ||
i had a similar problem after fitting a new motor and a 5 speed in my old ea, and it ended up being the map sensor from what the mechanic told me
