Old 03-12-2005, 05:30 PM   #1
LUXO_8
windsor user
Default best way to remove badges....
hey just wondering what the best way to remove badges from the guards without scratching the panels........
wanna take the badges off my guards finally...... over it:P
Old 03-12-2005, 05:35 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
fishing wire, i ended up using electrical wire though, ended up takin a few bits of wire but it came off.
badge is significantly smaller too (i was doing door moulds)
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 03-12-2005, 05:43 PM   #3
LUXO_8
windsor user
i was thinking some fishing line would work myself actually....
what would be best to remove the sticky crap thats remaining???
Old 03-12-2005, 05:46 PM   #4
Falcon Freak
Falcon Freak's Avatar
Obtain a hair dryer and blow onto the badge and guard to warm them. Once warm slowly lift the badge off the guard using a plastic scrapper. You may need to apply heat to the badge more than once depending on what type adhesive has been used.
I use prepsol.
FF
Falcon Freak is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 05:49 PM   #5
RUKIDN
Missing the boost :(
mine seemed to come off pretty easy! just slowly pulled it off with my fingers and only had a little glue left which came off with a bit of a clean and polish _2:
BA XR6 Turbo
301rwkw mild tune
Modified by XR6Turbo Developments
RUKIDN is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 05:55 PM   #6
neb
hibernating
neb's Avatar
if you have a heat gun it helps heaps... or a hairdryer should also help
neb is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 05:57 PM   #7
LUXO_8
windsor user
sweet, i might give hair-dryer a go......the only heatgun i have access to would disolve paint...lol
Old 03-12-2005, 06:13 PM   #8
Falcon Freak
You want to warm up the adhesive so that it is easier to remove the badge. You don't want to apply so much heat that it damages either the badge or the paintwork.
FF
Old 03-12-2005, 06:32 PM   #9
LUXO_8
windsor user
well badges and 99% of residue are gone....fishing line trick worked wonders, ta john...
just gotta get some polish onto the panels to remove a bit of crap that remains
Old 03-12-2005, 07:45 PM   #10
ilsautomotive
Former E-Series Member
I used a combination of eucalyptus oil and kero to get the glue off.
Get pics when you're done.
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 07:49 PM   #11
LUXO_8
windsor user
will do, need to get some cutters onto the paint cos its looking a little wierd / faded on the drivers guard, and also some moron had drilled holes in the guards to fit the cobra badges...grr..
ive got a couple of little LTD doortrim badges that will look great there to cover up the holes... (considdering im making it into an LTD mockup shouldnt look out of place)
pics sometime during next week after ive cleaned it up a bit
Old 03-12-2005, 07:50 PM   #12
Gunns
Gunns's Avatar
finally bye bye cobra!
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 10:45 PM   #13
b2tf
not here much anymore
b2tf's Avatar
No to the hairdryer method, if youve got crappy paint or even just a little sooky bit it can bugger it up. Safest way is to get a piece of dental floss, fishing line or something similar - then but strong, slowly work it behind the badge and just run it across to pretty much slice the badge away from the car.
To remove the crap left over, use some eucalyptus oil, then give the car a good wash, then use paint cleaner to do a top notch job.
2024 F150 XLT
Old 03-12-2005, 10:55 PM   #14
Falcon Freak
My farther was a spray painter and the hair dryer method is what he used. It is effective in removing badges and pinstripes without damaging the paint (if done correctly).
FF
Old 03-12-2005, 11:00 PM   #15
RG
Back to Le Frenchy
RG's Avatar
Can you remove the falcon gli badges from an EL using this method without leaving holes?
Originally Posted by drew`SEVNT5
nah mate, aussie cars are the besterest and funnerest, nothing beats them, specially a poofy wrong wheel drive
RG is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 11:08 PM   #16
LUXO_8
windsor user
i could be wrong but i think that badge has locators that slot into holes in the panel.....
Old 03-12-2005, 11:14 PM   #17
b2tf
b2tf's Avatar
On EF and EL the rear badges have holes behind them - that goes for the Falcon one and the Ford badge.
Typically any badge thats on the side of the car like an XR6 badge etc wont have holes behind it but you do have to check for the ones on the back. EF/L definately have them and the best way to find out if there are holes there or not is to take the taillight out, stick your hand in the cavity and reach down behind where the badges are located. If there's holes there you'll feel em.
2024 F150 XLT
Old 03-12-2005, 11:16 PM   #18
RG
Back to Le Frenchy
RG's Avatar
Bugger looks like i'm stuck with them then. Thanks guys.
Old 04-12-2005, 11:15 PM   #19
Psycho Chicken
Psycho Chicken's Avatar
I used a heat gun to take pinstripes off knackered 26 year old paint and didn't lift a single flake of paint.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2005, 12:46 AM   #20
snypereb
[EBGLT]
snypereb's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
Fishing wire is a great idea! I did mine with a flat screw driver they came off ok! But the fishing wire would make it riskless for stuffing up!
[EBGLT]
Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/
snypereb is offline   Reply With Quote Multi-Quote with this Post
