Old 24-01-2013, 09:05 AM   #1
peterljohnson55
peterljohnson55's Avatar
Default Stabilizer Bar Assembly - What type?
As per my photos attached, I have the Stabilizer bar assembly with the bar coming in under the lower control arm.
Other pics I have seen, such as in Ellery's manual, show bar over top of arm connecting to a spacer.
Can someone please identify the type of suspension system that I have in my 2001 AU2 Fairmont Ghia Tickford, please?
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2013, 09:11 AM   #2
jpblue1000
jpblue1000's Avatar
Default Re: Stabilizer Bar Assembly - What type?
you have standard series 2/3 front suspension. the series one was like earlier falcons with the anti-roll bar connecting above the control arm as per your description of the ellery manual.
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2013, 11:31 AM   #3
peterljohnson55
jpblue, is mine simiar to XR6, or are Series 2 and XR6 suspensions quite different beasts?
Old 24-01-2013, 11:45 AM   #4
jpblue1000
jpblue1000's Avatar
As far as I am aware, not owning an XR6, the suspensions are identical bar perhaps spring rate, ride height anti-roll bar diameter and maybe bush stiffness. but the parts geometry are exactly the same and totally interchangeable.
JP
Old 25-01-2013, 09:45 AM   #5
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Hi Peter.
Yes S2/3 are the same across the range, including the XR. To show you the difference between stock and aftermarket, here is a shot of my whiteline adjustable on my S2 LTD.
Stu
2002 AU II LTD
2002 XR8 pursuit 250
auIILTD is online now   Reply With Quote Multi-Quote with this Post
Old 25-01-2013, 11:59 AM   #6
peterljohnson55
Thanks Stu and JP.
BTW, on my last photo, do you think the sway bar should be bolted up tight to the joint, or is that gap (maybe 5mm?) acceptable?
Peter
Old 25-01-2013, 01:36 PM   #7
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
I assume you are referring to your last pic? A gap will be fine. As long as the nut is tight. You do not want the bar to be squashing the rubber boot.
Stu
2002 AU II LTD
Old 25-01-2013, 01:41 PM   #8
jpblue1000
jpblue1000's Avatar
by the looks of it, its done up to the shoulder on the ballstud so is tight. if it is loose it will rattle and bang and destroy itself very quickly.
JP
Old 25-01-2013, 02:43 PM   #9
peterljohnson55
thanks guys, all very helpful indeed.
Old 26-01-2013, 12:41 PM   #10
peterljohnson55
While we have our head under the car, what is the name of the part stretching from upper control arm to lower arm, in the middle photo?
Old 26-01-2013, 01:49 PM   #11
jpblue1000
jpblue1000's Avatar
Spindle, Knuckle or some cal it an upright...assuming your referring to the part which has the stub axle and brake brackets mounted.
JP
