Old 30-01-2015, 04:49 PM   #1
tankclare
BURN RUBBER NOT OIL
tankclare's Avatar
Default FG PCM troubles
G'day.
I've just done an N/A FG Barra and Tremec TR6060 manual conversion into an EF Falcon and having trouble getting it to run.
I've tried using a mates BF PCM that has all the PATS disabled on it and it runs for a second or 2 and then cuts out. I understand that the BF PCM is a bit different to the FG. Anyway with the FG PCM plugged in it turns over but won't fire. I towed the car 3.5hours away to a tuner who said he could remove the PATS off the FG PCM but it was a failure. We removed the usual PATS off the PCM via a HP tune but it still wouldn't fire and kept chucking up anti-theft codes. He said that it usually works with the BA-BF setups so wasn't sure why it didn't work with the FG motor and said that Ford must have a hidden anti-theft setup with the FG.
I asked Matt Power about it and he said he was talking to Chris about it.
Are you guys able to help me out in anyway?
Guy
[TUFF4L] EF Fairmont Ghia build thread - http://www.fordforums.com.au/showthread.php?t=11381891&highlight=tuff4l
[SMOKES] FG XR6 build thread - http://www.fordforums.com.au/showthread.php?p=4795218#post4795218
tankclare is offline   Reply With Quote Multi-Quote with this Post
Old 02-02-2015, 10:51 AM   #2
Theo@BluePower
Bluepower
Theo@BluePower's Avatar
Default Re: FG PCM troubles
Give us a call guy and we should be able to sort you out..
03 9305 3000
Bluepower website
47 Cooper Street Campbellfield Vic
03 9305 3000
Theo@BluePower is offline   Reply With Quote Multi-Quote with this Post
