15-08-2015, 03:55 PM | #1 | ||
can the heater switches be removed by just removing the radio suround panel as that panel clips in to the big oval dash suround thanks
15-08-2015, 04:35 PM | #2 | ||
Hi. You need to remove radio to expose 2 screws holding the big oval panel in place. After the screws are out the panel clips in place. Cheers MD
15-08-2015, 05:47 PM | #3 | ||
16-08-2015, 03:40 PM | #4 | ||
The radio comes out first, then the heater controls. Then the oval facia.
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
16-08-2015, 06:29 PM | #5 | ||
Hi. If its a factory radio the front of the radio is fixed to the rest of the unit. If it is an aftermarket radio it will be mounted in a sleeve that will stop access to the screws. Either way the radio will need to be removed. Cheers MD
16-08-2015, 08:18 PM | #6 | ||
Spanner Thrower
i know series 1 AU's have 4 screws holding the tear drop, pretty sure S2/3 would be the same. but heater controls on the S1 i know are held to the teardrop with 5 screws, not sure with S2/3.
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
16-08-2015, 11:25 PM | #7 | ||
yes there are 4 screws that hold the heater switches to the oval surround which tells me the the whole oval panel must be uncliped to get to the screws
