22-02-2006, 08:41 PM | #1 | ||
Walking with God
I have one stripped wheel nut. The thread on the bolt looks almost salvagable, but the nut itself is trashed! How do I go about fixing it?
I was thinking that SuperCheap or Repco would have a kit, and I would use those locking grips to twist the old bolt out and screw the new one it. Then just apply the new nut! This sound about right? GK |
22-02-2006, 08:56 PM | #2 | |||
Cheers Simon |
22-02-2006, 09:00 PM | #3 | ||
they call me Tibbo
front or rear? they just press in from behind
22-02-2006, 09:04 PM | #4 | |||
AFF's 1st DM.......
Location: Wha???... There is only 2 states 2 be in.. WA or Drunk..
you have to whack the stud with a drift. you may be able to do with without removing the disc . then the new stud will get hammered in from the inside of the hub outwards.
The studs come with tiny splines and the head is flat n larger. no chance trying to twist it out sorry mate
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
22-02-2006, 09:55 PM | #5 | ||
Walking with God
Thanks for the replies fellas. I'll get it seen to this weekend.
GK |
22-02-2006, 11:30 PM | #6 | ||
get a new set of nuts!! not hard
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
