Old 30-05-2006, 09:39 PM   #1
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
Default Au edit
Hey all just a quick one can the edit adjust and calibrate the speedo like if you put gears in can you make it suit the gears and read correct again.
cheers shaun
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2006, 09:40 PM   #2
Casper
Contributing Member
Casper's Avatar
No. The speedo is controlled by "cog gear" in the transmission. The edit can adjust shift points for the auto but not calibrate the speedo.
Older, wiser, poorer.
Old 30-05-2006, 09:42 PM   #3
NeishaXR8_347
SS Grunt
ok thanks so what cog gear would you get for 3.9's i now have the std 3.45's. i thought you could cause a mate got his speedo done on a cv8 monaro with the custom tune.
Old 30-05-2006, 09:47 PM   #4
Casper
Contributing Member
Casper's Avatar
Holdens are different I assume. As for gears, I'm not sure, I still run stock factory 3.45 diff myself.
Old 30-05-2006, 09:49 PM   #5
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
this is the closest thing i have seen to calibrating the speedo in a car with an ecu , its a jaycar device http://www.jaycar.com.au/productView...=&SUBCATID=347
:eclipsee_
XR6-VCT-2000 is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2006, 09:52 PM   #6
Casper
Contributing Member
Casper's Avatar
This may help:
http://www.aufalcon.com/Articles/Gears.htm
Old 30-05-2006, 09:53 PM   #7
NeishaXR8_347
SS Grunt
Thanks xr6-vct-2000 for that, its what ill prob try and use i read about it ages ago but since i have the edit i thought it would be simple to do.
thanks for info.
Old 30-05-2006, 09:58 PM   #8
XR6-VCT-2000
Fantastic Plastic
thanks for info.
no worries , it was just by coincidence i accidentlly stumbled accross it again the other day on the jaycar site while looking for something else , i forgot all about it ..lol ..I have heard of people using this device to calibrate the speedo with an ecu controled car , works fine too ;) .
:eclipsee_
Old 30-05-2006, 10:07 PM   #9
scotty_d
scotty_d's Avatar
I've heard of aftermarket 3.9 speedo cog gears going on ebay. Don't know if it's true or not. Might want to keep a lookout.
Cheers Scott
scotty_d is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2006, 10:10 PM   #10
XR6-VCT-2000
Fantastic Plastic
Cheers Scott
imo actually 4.11's even without a stall convertor is quite an everyday drivable car and gets up and boogies too when needed .
:eclipsee_
Old 30-05-2006, 10:43 PM   #11
xr8ute
Back on the road
xr8ute's Avatar
I know that the speedo gear can be changed to fix a diff ratio change, but I thought there where also scalars in the EEC for things like tyre size and diff ratio..?
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2006, 06:15 PM   #12
rayner22
rayner22's Avatar
^^^^ The ECU has a listing of different rim sizes, tyre sizes etc , not sure about diff ratios tho, guessing it would as the gears would run at different speeds with a different diff ratios. I gotta go see how to get my speedo adjusted since i got 18"s so I'll find out if its got diff ratios in it too.
rayner22 is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2006, 06:33 PM   #13
howesy
howesy's Avatar
jaycar product will only alter signal within a narrow band i think 4% so check speed with a gps and get an idea how far out it is and check specs on Jaycar unit.
howesy is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2006, 08:51 PM   #14
XR6-VCT-2000
Fantastic Plastic
the adjustment on the jaycar product is a whopping 0% - 99% , plenty enough to calibrate even a speedo out by 100k or so probably..lol
:eclipsee_
Old 01-06-2006, 07:37 AM   #15
FS5
how hard are these jaycar thungs to fit ?could an auto electrician fit it ?
i'm no good with electrical stuff.
FS5 is offline   Reply With Quote Multi-Quote with this Post
