Old 24-07-2006, 09:36 PM   #1
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
Default lukey extractors compared 2 pacemaker
i've been quoted $300 for lukey extractors, not sure which model??? repco stock anyway.
i was keen on 4499's for the sound, anyone know the specs of the lukeys?
hows the price?
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2006, 10:18 PM   #2
XRated
Shoot.
XRated's Avatar
Mate check the For Sale section as EASPRINT organises a good price on the Lukey's.
20V Turbo
XRated is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 08:19 AM   #3
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
to answer my own question
Lukey
Primary 38mm
Secondary 41mm
Pacemaker 4499
Primary 41mm
Secondary 48mm
BA MK2 XR6T
Old 25-07-2006, 08:58 AM   #4
BI6TIM
SnortPerformance.com
The pacemakers is where it's at man, get the pacemakers. I have those pacemakers, I like them.
BI6TIM is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 09:08 AM   #5
Simmo
White Lightning
Simmo's Avatar
yeh after BI6TIM pointed out how ghetto my lukeys are compared to paceys i gotta say go the pacies. my lukeys are press bent with pretty small primarys and a poorly designed collector. for sure they are way better than stock, but if you can go the paceys they are the better option.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 09:12 AM   #6
BI6TIM
Love that photo in your avatar Simmo. Looks hot as!
Sorry to get away from topic there. Ok the Lukey's that I have seen run into a final collector WAY too early(up near the front of the bell houseing). The difference between a 38mm and 41mm primary pipe is Huge for mid range pull.
The pacemakers a mandrel bent and have that pipe over design that is pacemaker only, plus they have some length to them and sit the 'cat' down near the back of the gear box, which somehow makes power(been proven several times). Which ever way you look at it the Pacemakers win from every angle except price. They are more expensive but worth it in the long run.
Old 25-07-2006, 09:21 AM   #7
OED666
OED666's Avatar
go pacies!!! no question about it...
Powered by Rollin Motorsport
Turbo Barra ED 4L
OED666 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 05:15 PM   #8
TUF_302
The Vengeful One
TUF_302's Avatar
Ive got a 2.5inch exhaust system on the car already and it sounds good and alot better than it did, but will a set of extractos make it even louder?? me want even more noise!!! :
TUF_302 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 06:45 PM   #9
Go Fords!!
CRU63R
Go Fords!!'s Avatar
I have lukey extractors on my car (cheers EASPRINT!) and I didn't find that the noise changed noticeably...not sure about the paccies...but only difference I found is that the engine revs a bit easier and no doubt is an improvement over the stock exhaust manifold
THE CRUISER
1963 1/2 Galaxie 500XL 2dr Fastback
390FE
Auto
Bucket Seats
Go Fords!! is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 06:46 PM   #10
TUF_302
The Vengeful One
TUF_302's Avatar
Well how would i get more noise from my car then, i got the 2.5 system but dont wana go 3 becasue ill just loose performance, how do i get me a louder falcon!!
Old 25-07-2006, 07:01 PM   #11
1TUFFUTE
1TUFFUTE's Avatar
get a hotdog at the rear instead of the last muffler bud...
1TUFFUTE is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2006, 09:40 PM   #12
EF_Frmnt
EF_Frmnt's Avatar
run only one muffler instead of 2 and a resonator. i have this on mine sounds quiet at idle but noticeable.. up it and its loud.
EF_Frmnt is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 12:21 AM   #13
ROOSTA
DFDFDF
ROOSTA's Avatar
Or just run the same as me.. single muffler.. and thats it.. sounds very loud.. if you want louder.. do as they said above.. but just run a hotdog alone.. lol.. or better yet.. dont run an exhaust at all.. just dump it out after the cat..
LOL
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2006, 07:26 AM   #14
BI6TIM
SVO XR6, put some extractors on the thing first and see how you like the sound and then think about changing the rest of the exhaust for more noise if you still want.
I found a noticable change in exhaust note when my Pacemakers went on, I also had a 2.5inch mandrel bent system on the car before hand. I've found with the Pacemakers, high flow cat, 2.5inch mandrel bent with one large mufler and a hot dog behind the rear bumber is the perfect setup. It's not too loud if you need to roll passed the police or your girlfriends parents house late at night, but if you get into it people deffinately know you have your right foot down.
Again buy the Pacemakers.
Old 26-07-2006, 10:34 AM   #15
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
buyin the pacemakers
w00t!
BA MK2 XR6T
