Old 05-09-2006, 05:10 PM   #1
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
Default New Problem!
just went out and used some splitters on the sub rca's. sounds no where near as good as it did on the old cd player. WAY less volume. i am running 2 monoblocks which are running two 15's. it also seems that the louder i turn it up, the less volume the sub produce but the more the rest of the speakers produce. what can be causing this???
i tried turning the gain on the amps up but that made it worse. i thought that the sub out on the DVD player was 4v. but when i set the gain on both amps to around 4v its still sounds quiet. even more so actually. WHAT CAN I BE DOIN WRONG???
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2006, 05:12 PM   #2
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
try your ground may be that
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2006, 05:15 PM   #3
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
i'll double check all my earths then
Old 05-09-2006, 06:13 PM   #4
RMCprime
EF XR6 5spd
when i did mine 1 of the rca's was touchin metal and shorting, causing it to do the same thing you are describing with the volume.
also i think the pre-out voltage is always less than what is quoted in a similar way to the difference between power rms and power max.
try askin some 1 on this forum
http://www.caraudioaustralia.com/forums/index.php
here is a tute on gain setting which i followed http://www.caraudioaustralia.com/for...l=gain+setting
RMCprime is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2006, 06:50 PM   #5
tickford_ghia
EL Fairmont Ghia
tickford_ghia's Avatar
on your cross overs.
Try changing one side to either high pass freaquency (HPF) or Low pass freaquency (LPF) and change the other side to off.l
This fixed the prob in my mates car.
Me: Jarrod
Car: Burgandy EL Fairmont Ghia
Tickford options (inlcuding kit and wheels but no f'n LSD) Stage 2 Shift Kit, Lowered, Roof, bla bla bla
tickford_ghia is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2006, 06:38 PM   #6
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
i have tried ALL of thisand still no luck. no matter what combonation or settings i use, the subs get very quiet above about 50% volume!
HELP GUYS!!! i just spent $1300 on a DVD player and at the moment is sounding worse than my $300 cd player!
Old 06-09-2006, 08:59 PM   #7
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
are the rear RCA outputs being used? try using rear output insted of the splitter.
EF Wagon Project:
Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required
Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB
Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's
the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA
CaRtZ is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2006, 08:11 AM   #8
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
i have tried this also. NO LUCK!
Old 07-09-2006, 09:01 PM   #9
CaRtZ
Aspiring mr efxr
CaRtZ's Avatar
hmmm. real head scratcher u got here... call the manufactuer of headunit and/or amps. ask them
EF Wagon Project:
Old 07-09-2006, 09:04 PM   #10
niko
likes falcon's
niko's Avatar
try a new set of rca's
www.carhubsales.com.au
niko is offline   Reply With Quote Multi-Quote with this Post
