Old 13-12-2009, 10:55 PM   #1
R0BD0G
R0BD0G's Avatar
Default Lynx 1600 Manifold.. question...
after changing manifolds from the standard down draft manifold to the lynx side draft and 40 DCOE weber. ive had fun with the vacuum lines and vacuum advance bits and bobs... but where does the heater hose run that was plumbed into the bottom of the standard manifold... coz theres the one that ive got running into the top of the water pump... but the short one that should run into the bottom of the manifold i dont think there is a hole there for it?
a solution anyone?
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2009, 06:23 AM   #2
Puzzlescort
Rally Nut
Puzzlescort's Avatar
rob
the one on my 1600 had a connection underneath about an inch out from the head in the middle between no. 2 & 3 cylinders
can you see if there is 'water compartment' on the manifold (when off)
Maybe the one you have doens't suit a heater???
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2009, 07:28 PM   #3
R0BD0G
R0BD0G's Avatar
i found it today when i was having a good inspection. seems a pita to put a fitting on to... to the speed shop tomora for more pro flow gear
Thread Tools
Display Modes
