13-03-2010, 01:41 AM | #1 | ||
[ 5L ]
my alternator bearing stuffed up the other day just checking if it is possible to replace the bearing or if im up for a new alternator.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
13-03-2010, 03:07 AM | #2 | ||
Yes; but a new or rebuilt exchange alternator might be easier, not much more expensive and will last much longer.
regards Blue |
13-03-2010, 03:21 AM | #3 | ||
And ebay has new ones $210 post free http://cgi.ebay.com.au/Ford-Falcon-A...item27b00d717f
regards Blue |
13-03-2010, 03:39 AM | #4 | ||
[ 5L ]
cheers for the quick response
13-03-2010, 04:02 AM | #5 | ||
i don`t think they`ve got to the throw away stage yet, yes you should be able to replace the bearings , if i remember correctly you need to pull it down remove bearings with a puller or a press, ....ahah! check this out good ole youtube, there are many other clips, this gives you a rough idea ;)
13-03-2010, 04:15 AM | #6 | ||
The Destroyer
Good time to upgrade to a MSD alternator.
Toy- Blown XR8 Ute. Black on black "Front-drive cars are for children" |
13-03-2010, 11:29 AM | #7 | ||
http://www.youtube.com/watch?v=qJGbi1A4CBA sorry my bad .....hey i`m old :
13-03-2010, 01:59 PM | #8 | ||
Not a bad video but I would replace all, rather than relube any bearings. Also as the worn bearing have often spun in the aluminium seat, and no longer fit as tightly as they should, it pays to use Loctite or Permatex Bearing retainer compound to retain the new bearings in their seats.
In any event, I no longer bother to replace the bearings in alternators, as I've always found that usually 12 to 18 months after the bearings are replaced the alternator fails - it seems the overheating from the worn bearings fatigues the stator and or rotor wiring and the fail. So now I just get an exchange alternator.
regards Blue |
14-03-2010, 12:48 PM | #9 | |||
My main concern is whether the 2 wires have exactly the same function, regardless of brand. |
14-03-2010, 02:42 PM | #10 | ||
Usually the two wires serve the same purpose but the difference in alternators between models is usually about pulleys and mounts so a later model may not easily be retrofitted. Someones else here who has tried should know. There are other AU-1 alternators on ebay.
regards Blue |
14-03-2010, 02:45 PM | #11 | |||
OK can be made to fit with an adapter see: http://cgi.ebay.com.au/Ford-Falcon-F...item3efa17612a
regards Blue |
15-03-2010, 10:26 PM | #12 | ||
AU1 Visteon alternators were very hard to repair
AU2 and up Mitsubishi alternatore can be pulled apart in 10 minutes the main front bearing just taps in and is retained by a cap, the rear one does need a small puller, brushes can be changed, so can the regulator I always regrease bearings, haven't bought one for years, do them every 100000kms, or if you get power steering oil in them AU1 different to 2 and 3 BA different again BF different again |
Thread Tools | |
Display Modes | |
