17-03-2018, 10:34 AM | #1 | ||||
By Jeff Smith March 16, 2018
http://www.fordnxt.com/tech-stories/...-need-to-know/ Quote:
http://cdn.speednik.com/wp-content/b...-32_427768.jpg Quote:
17-03-2018, 11:15 AM | #2 | ||
Hey S.G!
E85 and LPG both have very similar octane ratings and they also both help cool the intake air/oxygen on the intake stroke which helps make a bigger bang. One good thing i have been noticing lately is that E10 has been 4cents cheaper than 91 (United servo's) which now makes it sort of worth buying as previously i would'nt buy it as it was only 2 cents cheaper than 91. I'm going to start running E10 in my wagon and my bike i think. Will keep an eye on tank ranges and its also 95 octane so you should get a bit more power/performance. |
17-03-2018, 11:40 AM | #3 | ||
Hi CB,
Around here we can't get away from E10 or E15. But the way they formulate it, nothing changes with the octane or the cost. Nothing we can do about it legally. Cheers. |
17-03-2018, 11:48 AM | #4 | ||
bitch lasagne
It also needs to be said that running E10 in a fair amount of the cars on the road in Australia is a false economy. This is due to the increased fuel consumption more than offsetting the small discount at the pump.
6 users like this post: |
17-03-2018, 12:02 PM | #5 | |||
Unfortunately it is incomplete for E10, but still gets the idea across at standard AFR. It drops from 14.7:1 to 14.0:1 ~ 14.1:1 at standard AFR/stoichiometric. For folks not familiar that is a mass ratio not volume of air to fuel. Last edited by solarite_guy; 08-09-2018 at 09:11 AM. |
17-03-2018, 12:20 PM | #6 | |||
BLUE OVAL INC.
We've recently had a Liberty open up in our area which carries e10, at some point in every week the e10 is as much as 30c cheaper than the 91 ulp and as a result is cheaper to run it. We keep our cars above 50% full where possible which allows us to get through the cycle and take advantage of the cheaper e10, 35l in my wifes Camry at 30c less per litre saves around $10pw and only pushes the average consumption out by .5l/100km. In addition, my Sons VE is a flex fuel model and runs much smoother on the e10 than 91ulp. |
17-03-2018, 02:15 PM | #7 | ||
A list of material compatibility with E85.
AUII XR6 VCT ute 20 years and still going strong! Last edited by Bill M; 05-11-2018 at 11:06 AM. |
2 users like this post: |
17-03-2018, 02:29 PM | #8 | |||
bitch lasagne
17-03-2018, 06:03 PM | #9 | |||
Unless E10 is about 10 cents a litre less, it's really not worth considering... |
17-03-2018, 06:21 PM | #10 | ||
Sorry, I thought it was self explanatory.
What would you say, 14:1 is roughly 5% less than 14.7:1? Little less. So to roughly break even I would want the E10 to cost about 5% less than the straight petrol. Some times my pit road thinking doesn't translate the way I think it would. |
17-03-2018, 11:47 PM | #11 | ||
Wirlankarra yanama
The energy derived from burning fuel (which is what an engine does) is heat. Heat/Energy is measured in BTU not in Stoichiometer.
E85 has roughly 72% BTU compared to gasoline. E10 has roughly 98% BTU compared to gasoline. LPG has roughly 80% BTU compared to gasoline. Diesel has roughly 113% BTU compared to gasoline. Using BTU is a high level explanation of what is happening. An engine needs to consume more E10/E85/LPG to create the same energy as it would have to if it ran on gasoline. This explains why diesel vehicles get better mileage than their gasoline cousins too. |
5 users like this post: |
18-03-2018, 12:24 AM | #12 | |||
Former BTIKD
18-03-2018, 03:20 AM | #13 | |||
That's why I like the standardized tuning references expressed in stoichiometeric value. Of course those are simply baseline references. Each particular engine build will have it's own variation. Last edited by solarite_guy; 18-03-2018 at 03:30 AM. |
18-03-2018, 12:31 PM | #14 | ||
Frankenford pilot
Wish I had read up on E85 before I built my motor. I was asked what fuel I intended using I went with 98.
Cheers Bretto 73 XB GT Last of the Big Ports |
18-03-2018, 12:58 PM | #15 | ||
It's true, from a power standpoint the E85 has the potential for more power and less chance of damaging detonation, etc. The pita aspect is in the consistency/inconsistency of what you may get from the pump.
What I've seen a lot of folks like better is VPs C85. They keep it sealed in a drum in a dark cool place. Being in drums, the dark part probably doesn't help much. |
18-03-2018, 02:27 PM | #16 | ||
18-03-2018, 06:46 PM | #17 | |||
Frankenford pilot
The local po po have a thing about bald tyres and bonnet scoops
19-03-2018, 07:15 AM | #18 | ||
The one and only
It reads like a salesmans pitch.
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
19-03-2018, 06:31 PM | #20 | |||
Other factor to consider is that E10 is 10% renewable. |
19-03-2018, 06:56 PM | #21 | ||
Great posts Gents. I happily admit I knew little about E85 so I was glad to get some facts. Out of curiosity, I went to a couple of servo's that are listed as suppliers of these fuels to find they are not stocked. It seems that only a handful carry these fuel types which must make it difficult if the car is tuned to run on it?
19-03-2018, 08:27 PM | #22 | ||
Thers a new LPG system being developed at the moment that will blow the doors off most petrol XR6T/F6310 or V8 GT's. ( And also 6.2 Litre LS3's)
Give me a couple of months and we'll have the new website up to date with all the info on how the system works. We're aiming for 400-500KW's from XR6T/F6310 Barra engines. |
19-03-2018, 11:13 PM | #23 | |||
19-03-2018, 11:23 PM | #24 | |||
bitch lasagne
20-03-2018, 01:32 AM | #25 | |||
Yes you use up more but also get more killawasps Difference is like 5% or so more usage then comparable 95 but also 50cents cheaper per litre. $1.10 E10 $1.59 95ron all day Even topping up half tank 35litres I can save $17.15 Double that saving for a full tank Oh and use the NSW Fuelcheck app if in NSW and can see prices of favourite stations in area you save as a favourite. Great app Sent from my ASUS_Z00AD using Tapatalk
Before - ED Falcon Futura (sold) EL XR6 (R.I.P.) VX SS (R.I.P) VE Berlina |
20-03-2018, 12:23 PM | #26 | ||
Here is an interesting article related to these fuel types in the states.
https://www.hemmings.com/blog/2018/0...el/?refer=news |
20-03-2018, 06:21 PM | #27 | ||
I sort of get the feeling a lot of people are against the idea of ethanol, but I for one are all for it.
So let look at it from my point of view. I was travelling to work, same route, same time very day, and My BF Falcon ute was getting 16.3 litres/100km on E10 according to the vehicle average fuel meter. When the E10 was discontinued (it's no longer available here), I switched to premium 95 and was getting 16.1 litres/100km. 0.2liters/100km don't seem much to me but still, lets work it out. Now we need a bit of back ground information here. My ute is designated to run on unleaded 92, E10, or Premium 95. On unleaded 92, it tends to be a little sluggish with a slight deterioration in fuel economy. On E10 and premium 95 it seems to be more responsive. E10 here was 95 octane. And E10 at the time was cheaper than unleaded 92. Today the average price for fuel is- ULP 92 is $1.456 per litre. PULP 95 is $1.592 per litre. Lets do the math- My car was using more E10 and using todays price for ULP92. 16.3/16.1 X $1.456 = $1.474.......approximately for the same distance travelled. But premium is $159.2 for the same distance travelled. So E10 was cheaper in the long run. I never ever had any problems with the fuel, and I must admit I did change to the E10 because I am a bit of save the planet, but I am also an obsessive car enthusiast and it was my way of having it both ways. Peter |
21-03-2018, 11:21 AM | #28 | |||
Now in such a case of E10 94 octane most will pick up on performance for sure and as to fuel economy generally no. Now my VY SS could get the same economy on the highway with E10 94 and 91 an 95 and 98 proven time and time again if driven easy, but with air-con on E10 failed badly and if one drove harder E10 fails. Their is a E10 91 getting around as well and I found it still performed a bit better than 91. My wife's Aurion went like a rocket on E10 94 when I drove from Brisbane to Adelaide and back, out west did not have E10 and yep I could feel the difference for sure when flat to the boards over taking, I was really impressed with E10 94 and with the 91 it was like no this is not impressive at all. |
21-03-2018, 01:30 PM | #29 | |||
Hunger is morally compelling. In 2000, over 90% of the U.S. corn crop went to feed people and livestock, many in undeveloped countries, with less than 5% used to produce ethanol. In 2013, however, 40% went to produce ethanol, 45% was used to feed livestock, and only 15% was used for food and beverage (AgMRC). Unfortunately, Brazil is clear-cutting almost a million acres of tropical forest per year to produce biofuel from these crops, and shipping much of the fuel all the way to Europe Humans originally switched from biomass to fossil fuels because biomass was so inefficient, and took so much energy and space to produce. So far technology has not reversed these problems sufficiently to make widespread use beneficial. Morally the case for ethanol is weak when you consider the impact it has on food prices for those that can least afford it. |
21-03-2018, 01:39 PM | #30 | ||
*barks incessantly
Thread Tools | |
Display Modes | |
