Old 27-10-2006, 09:43 AM   #1
The Mighty Red
The Mighty Red's Avatar
Default power windows
I'm thinking about installing power windows to the front doors on the XR6 .
With our XR6 not having power windows from the factory , Will my ECU have the neccesary plug in for the power windows to operate or will i need a different ECU ?
The Mighty Red is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 09:45 AM   #2
Mechan1k
Mechan1k's Avatar
Damn ... I thought all XRs came with at least FRONT power windows.
Must be a Series 1 model.
Unless it's a lower model that has been made up to look like an XR6???
Old 27-10-2006, 09:50 AM   #3
HLC
Audi S3
some of the early XR's didnt have power window fronts.
Old 27-10-2006, 09:58 AM   #4
The Mighty Red
Its deffinately an XR6 lol , I rang Ford with the relevant vin numbers etc before I bought the car.
It was made in the first month of the Series 1 AU , Sept 98 , Someone awhile back put up some stats about the numbers with different options and there were about 60 AU XR6 with no power windows .
Old 27-10-2006, 11:46 AM   #5
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
wow sept 98, thats old!
Old 27-10-2006, 01:52 PM   #6
LG
LG's Avatar
You don't need to touch the ECU. It's the BEM that controls this function.
It should have it. But you don't even need to go through the BEM if you don't want to. You can just tap into some power, hooked up to the ignitition, to the switchs, to the regulators, and your done.
You will need:
- New Door Trims
- Switches
- Regulators & Motors
- Wiring etc or Looms from Ford
If you want it to look factory, and have the 60 second delay after you turn off the key, you will need to wire up a relay, or wire it through the BEM.
It's fairly costly, especially if you buy the Looms from Ford.
AUIII Falcon Forte, with SIX Appeal
LG is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 02:09 PM   #7
The Mighty Red
Thanks LG! I am planning on getting a setup from maybe a late model Forte that has just the fronts and get the black switches from Ford and do a straight transplant , wasnt sure about the door trims but yeah , they will probably be costly.
The only place I have spoken to hasnt got back to me yet ,so I really have no idea how much it all will cost.
thanks again..
Old 27-10-2006, 02:50 PM   #8
LG
LG's Avatar
http://cgi.ebay.com.au/Ford-Falcon-A...ayphotohosting
If you can get that, then perhaps sell the seats and your existing door trims.
Each wiring loom is about $60-90. And if you get the one from eBay. It looks like you'll be doing a full 4-door power window conversion, which = $$$.
Old 27-10-2006, 02:51 PM   #9
LG
LG's Avatar
Here's another set to, which is just front's I believe...
http://cgi.ebay.com.au/FORD-AU-UTE-X...ayphotohosting
Old 27-10-2006, 03:30 PM   #10
The Mighty Red
hmmm , I wonder if he would split those door Trims : ,
Old 27-10-2006, 07:50 PM   #11
TwistedEL
TwistedEL's Avatar
Mate just wait for someone to wreck an AU on the forums or in the local papers you can pick up at least some of the parts for cheap
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2006, 07:51 PM   #12
TwistedEL
TwistedEL's Avatar
I just sold all 4 doors complete from an EF for $350 and that included the looms (cut em up tho)
