Old 08-12-2006, 04:51 PM   #1
nikos
mezzo forte
Default speaker upgrades
I have an au1 forte and i am upgrading the sound system. What speakers are easy to install in an au? I'm replacing both front and back. Has anyone managed to get 6" splits or 6x9s in without too much fuss? Also what are the dimensions of those funny sized stock speakers? Can you buy high powered 2 or 3 way spkrs in that size? Any help appreciated
nikos is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2006, 04:53 PM   #2
HLC
Audi S3
the stock speakers are 5x7"
people are getting 6" splits in the doors, just makeing up a wooden spacer, that screws into the 5x7 holes im assuming and mounting the speaker on that.
6x9's can be put in the rear parcel shelf. but need to be screwed in from underneath, unless you want to use a spacer on top of the parcel shelf.
Old 08-12-2006, 05:01 PM   #3
superroo
You can't stop the signal
superroo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Has done quite a few excellent write ups for au .com
this threads been done before
http://www.fordforums.com.au/showthread.php?t=48915
It all depends on the type of speaker that you get, cause i got 6inch speakers in my doors with no mdf spacer, juct had to make up a couple of brackets for it.
Originally Posted by Matt Brown
I own a Dodge Viper and a minivan, and if I could only keep one of them, it would be the minivan
superroo is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2006, 05:01 PM   #4
nikos
mezzo forte
ah...of course! Ta
Old 09-12-2006, 05:46 PM   #5
StAndArdAU
Back in a Blue Oval
StAndArdAU's Avatar
i put in Alpine 5x7's splits inthe front and 6x9 Pioneers in the rear,
'13 Territory TX Diesel RWD. The Family Bus
'08 Mitsubishi Pajero. The Off-road Machine
StAndArdAU is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2006, 11:06 PM   #6
TwistedEL
TwistedEL's Avatar
I put 6" in the front doors with a spacer made out of MDF as suggested
And I upgraded the factory tweeters
Chucked a sub in the boot
Didn't worry about the rears, I run them from the head unit and run the fronts & sub thru an amp
TwistedEL is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2006, 12:13 PM   #7
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Im Going to be Using Boxs On the Windows so i can fit my JLAudio 6x9's , and i scored a 8" Sub for the Hole where the Premo Sound Goes , Add that to the Dolby Tweeters and the 2 Venom Subs , Can you say rattle >
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2006, 12:58 PM   #8
nikos
mezzo forte
yeah think ill chuck me 6" splits in the front with a spacer, and the 6x9s under the back shelf. They should complement the two 12" pups in the boot :evil_laug
Old 10-12-2006, 01:19 PM   #9
duaned
duaned's Avatar
Seriously there is no need for 6 x9's if you have subs mate. The rear speakers are for rear fill only(passengers) so stick with nice 5 x 7's in the rear parcel shelf. The rears will be high passed if done properly anyway, say 80hz and up. Spend the bucks on good front splits and deadning, your ears will thankyou for it!
duaned is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2006, 03:33 PM   #10
stiddy
stiddy's Avatar
Just whack in 5x7's all round, splits up front, 2-ways in the rear.. no mucking around, no making/modifying, just screw them into the standard locations, amp them, run a sub and she's all sweet.
stiddy is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2006, 06:29 PM   #11
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
there was no Mucking around , i want the 6x9's because there Premo !
AU2PWR
Old 10-12-2006, 10:37 PM   #12
blackers10
blackers10's Avatar
my stock system sounds alrite being complemented by 2x 15" JLs in the rear and a JVC headunit and chinese in dash screen up front... the new headunit really helps the stock splits along!!
Old 12-12-2006, 12:22 PM   #13
xr8 007
xr8 007's Avatar
What happens if you just upgrade the existing 5X7 to something better, will it still distort??
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2006, 12:33 PM   #14
bonk182
BonK182
007 - they wont distort by upgrading the stock speakers. Just remember, you need to think about how they are being powered. a set of speakers rated at 80watts RMS are still going to distort if they are solely powered by a 15 - 20 wrms x 4 head unit - which most are. Running any speakers from an alternate power source than the head unit will give you far better results. try match rms values and you should be sweet.
James
bonk182 is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2006, 01:20 PM   #15
blackers10
blackers10's Avatar
5x7s will be fine if your just after a drop in solution
BUT be mindful of the mount DEPTH as some are a fair bit deeper than the stock location can take and will need spacers anyway! ( i beleive the alpines fall into this catagory)
but a spacer to fit 5x7 cant be hard to make as its just a case of traceing around the speaker
Old 12-12-2006, 06:27 PM   #16
bodes-sh
as far as stock speakers go, they are fairly decent with a decent head unit, i still have the stock ones in the front of mine with a sony mp3 player and they sound a lot better that what better speakers with a stock headunit would sound...thats my opinion anyway, if you have already got an aftermarket headunit then i guess a speaker upgrade does help
Old 12-12-2006, 06:33 PM   #17
StealthAu
standard speakers are fine, unless your amplifying them, then they wont sound to great.
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2006, 06:46 PM   #18
poolkeeper
Its Resonating!
poolkeeper's Avatar
And if you dont have them turned up that loud, lol
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2006, 09:06 PM   #19
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Lol , But the AU Parcel Shelf , the Speaker Grill is that weird 'Egg' Shape , the 6X9s need a Spacer , so im making some Plastic Ones , I Can Offload to you Guys if you Want ,
Should be ready in a few days
Daniel
AU2PWR
