Old 23-04-2007, 07:09 PM   #1
The Monty
Just slidin'
The Monty's Avatar
Default Diffs
Quick question, after a quick answer. Will an EA diff fit up to an AU?. If not, what LSD's are available for the AU, and what other models diffs are compatilble.
Thanks guys. :sm_headba
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2007, 08:23 PM   #2
Baboon_AU
Baboon_AU's Avatar
only falcon diffs fit in falcons.. they are so different to other sort of cars. falcon diffs pull out from the rear end of the car, the back plate comes off and the center will pop out. commodor diffs and most others such as a 9" pop out from the tail shaft side.
lsd available for the au's are an au 3.45 LSD from an xr6 or 8.
and i am 90% certain that the e series diffs fit into the au
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2007, 08:27 PM   #3
Casper
Contributing Member
Casper's Avatar
EA diff centres do not fit AU's. The EA was 25 spline and the AU is 28 spline. Any diff centre from EB onwards will fit an AU along with a few other diff centres like the Nissan Pintara (4.11) and Skylines.
As for LSD, that can be fitted on any AU Diff of any ratio if you want. Ford only really fitted them to the 3.45 ratio (and possibly the 3.23 on the Fairmonts) however it can be fitted to any size diff centre.
Older, wiser, poorer.
Old 23-04-2007, 09:14 PM   #4
private9
www.TUFFCARPARTS.com
private9's Avatar
Damn, damn, damn! Don't tell me that E series centres fit in AU's! I just flogged off my EL 3.45 LSD diff assuming I couldn't swap the centres over!
private9 is offline   Reply With Quote Multi-Quote with this Post
Old 23-04-2007, 09:17 PM   #5
Casper
Contributing Member
Casper's Avatar
meh, 3.45 is so "stock" : Go for a 3.9 or 4.11 set, so much more fun
Old 23-04-2007, 09:22 PM   #6
FGII-XR6
FGII-XR6's Avatar
the later e series centres will fit but not the housing or axles the au has a different offset
Old 23-04-2007, 09:30 PM   #7
Sleeperau
Highway Taxi
Default Lsd
A VL commodore diff centre 3.45 will drop straight in. You will need an LSD when the turbo is fitted though. I picked up a good AU LSD for $415. . The ratio is still not good enough though same as a Fairmont. Still better than a 3.08 though. Be patient and wait for an AU diff to come up.
Close only counts in Horse Shoes & Hand Grenades. :evil_laug
Sleeperau is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2007, 03:28 AM   #8
The Monty
Just slidin'
The Monty's Avatar
Yeah Im deffinately getting an LSD, but as its a Fairmont, and Ill be going turbo, Ill stick with the 3.22's. Thanks guys.
Old 24-04-2007, 08:56 AM   #9
StealthAu
All commodore diffs I've removed apear the same as the falcons. I'm not syaing they fit but they are removed from the back of the diff
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2007, 08:14 PM   #10
NC1183
NC1183's Avatar
So will a LSD out of a AU 1 one tonner fit into a AU2
Nathan
2005 FPV BF Super Pursuit
The new toy (now sold)
The SP
The old ute (sold)
www.aufalcon.com/nc1183
Build Thread
Originally Posted by F6T
If you look closely you can see the remains of a Hyundai excel that’s been sucked into the intake.
about the pic of 'CHOP YA' F6
NC1183 is offline   Reply With Quote Multi-Quote with this Post
Old 24-04-2007, 08:18 PM   #11
private9
private9's Avatar
What ratio have you got in yours mate?
Old 24-04-2007, 10:07 PM   #12
StealthAu
yes centre will fit
Old 25-04-2007, 03:23 PM   #13
EvilChief
Boost Addict
what drugs are you smoking?
commodore diffs with BW 8 3/4" diffs are the same as falcons ...
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 25-04-2007, 03:32 PM   #14
Casper
Contributing Member
Casper's Avatar
4.11's
