16-02-2007, 08:57 PM | #1 | ||
Focus is my middle name
I read a lot abt throttle bodies in american forums. They go on and on abt throttle response. Now I do understand theres no/marginal performance gain. But I wouldn't mind a bit more throttle response from my focus.
Has anyone down here tried them?...I wanna hear from them
2004 LR Ford Focus Zetec 3 door, Panther Black, Manual, 17" MP3 Alloys, SVT Airbox with K&N panel filter, SVT Snorkel, Leather Gear Knob and Steel Handbrake Cover, ST170 pedals, ST170 Lower grille, CFM UDP Not too soon : Focus sport/Borla Exhaust, Throttle body
16-02-2007, 09:34 PM | #2 | ||
Focus Rookie
ive got one!! Focus Central 65m... i picked up for 200bux but its sitting in my garage! they are hard to put in! i snapped my TPS twice trying!!!
im gonna get it put in next time i goto my mechanic!!! for my next service which is coming up very soon!
04' Panther Black Focus Zetec Custom Euro Plates, ST side indicators, MK2 Badges, ST Snorkel, White 17"s, Exhaust, Springs, Volant Intake,Angel Eyes, Body Kit, St170 Lower Grill, F/C Throttle Body, DBA slotters |
16-02-2007, 10:30 PM | #3 | ||
Keep me informed......Im getting one pretty soon anyway. Prolly FC or CFM
21-02-2007, 08:21 PM | #4 | |||
RODENT
Replacing the OE part with a 65 plus diameter thottle body MUST give the engine a noticable power gain. The least you are doing is allowing an increased air-flow IN to the system, the same way a free flowing air filter etc. does and so on through the engine to an increased diameter exhaust to allow the unrestricted air OUT. |
21-02-2007, 08:42 PM | #5 | ||
Contrary to popular belief, a larger throttle body does not necessarily give MORE air to the engine. Even though the dia of the throttle body is increased, the size of the inlet manifold remains the same.
What a larger throttle body does, is it gives the extra amount of air the engine needs ( like when u stomp the pedal), WITHOUT DELAY, instead of sucking it all the way from the airfilter. Hence the improvement in throttle response.
21-02-2007, 08:46 PM | #6 | ||
RODENT
Sorry 1lifeliveit, I stand corrected :(
21-02-2007, 08:58 PM | #7 | ||
Old enough to know better
It depends on the restriction. If the engine is getting all the air it can use, then creating a bigger inlet for the air will not improve air flow because the engine frankly can't use it. Otherwise you could simply keep going up in size in the throttle body and get constantly improving performance. (Let's try a 100mm throttlebody!!!)Similarly if a 3'' exhaust is allowing all of the exhaust gases to escape easily, then putting on a 4.5" exhuast is not going to allow even more exhaust gas to escape.(ignoring backpressure issues etc etc)
You can only increase intake and exhaust flows to a level where the cylinder head can handle it. Giving the head more air than it can handle won't increase performance. In the High-Performance Ford Focus Builder's Handbook, it suggests that the standard Focus throttle body is not, in itself, a restriction: "Adding the Focus Central 65mm throttle body resulted in a gain of 1-2 horsepower, with the majority of the gains coming after 4,000rpm. Apparently the stock throttle body did not represent much of a restriction at the power level" However when tested on a 200hp supercharged Focus (therefore more air being drawn through the system), adding the 65mm throttle body (before the supercharger) did show an increase of 12-13 horsepower On a turbo however (remembering that the turbo is before the throttle body) the 65mm showed no performance gain compared to stock throttle body, since the turbo was able to force sufficient air through the throttle body. Wish I could have said it shorter than that!!!! (And just saw there were two replies while I was typing!!)
21-02-2007, 09:21 PM | #8 | ||
RODENT
With ALL of that taken in to consideration, ie, the OE throttle body on a normally aspirated Focus not being a restriction, does anyone know if work can be carried out on it to improve the throttle responce. If this is the case, it could save some of us some hard earnt cash through not having to purchase a new throttle body from OS.
21-02-2007, 09:43 PM | #9 | ||
Non-Regular Member
On the LS focus you would need to get a flash tuner and change the throttle body mapping
21-02-2007, 10:22 PM | #10 | ||
U can port the OE throttle - which means instaed of buying a bigger throttle body, u can kinda shave the inner side of the TB to make it bigger. Im not a big fan of this. But....
See this http://www.focushacks.com/index.php?modid=58
22-02-2007, 12:33 AM | #11 | ||
Zoom Zoom
Run on 98 Octane, use a high flow air filter and good spark plugs and leads, that should keep it snappy all for less than the price of a Throttle body.
2012 Mazda3 MPS
22-02-2007, 12:53 AM | #12 | ||
I do all of the above...and it is kinda snappy...but I want it snappIER :-)
22-02-2007, 08:53 PM | #13 | ||
Zoom Zoom
Then I'm afraid you need to start spending big bucks for 1-2 HP. That or get a supercharger.
2012 Mazda3 MPS
23-05-2007, 11:17 PM | #14 | ||
Focus Rookie
Ok so i took my car in for a service and now im FINALLY getting my throttle body put in by my mechanic..
I previously tried to put it in myself with no luck.. My mechanic tried but he said the engine light came on and was idling rougly.. So apparently the holes that were pre drilled on the TB was wrong.. So he sent my car off to an auto electrician to fix it all up.! So i should get the car back tommorrow morning.. Im not expectin much power increase but hopefully the throttle response will be much better.. I shall let ya know!!
23-05-2007, 11:46 PM | #15 | ||
AFF Post NAZI
okay my turn.. hehehe
firstly.. me and my mum both have WP zetecs. my mums one is stock as a rock.. like stock.. on mine i have had a 2" cat back exhaust done with a pod filter and i only run 98... i noticed that the Resoponse on the car has Increased considerably to the point that when i get in my mums car and drive it (both manual) when i shift the revs dont have time to change/move up or down b4 i have it in the next gear..like when you take your foot of the accelerator clutch in then change clutch out and accelerate.. that car hasnt even responded to the fact that the accelerator isnt in.. basically. b4 you go mucking around with all that.. try getting an 2" catback exhaust, a cold air intake and run 98.. you will notice that it will become EXPTREMELY snappy cause you guys have cable driven TB's. mine is electronic... therefore there will always be that little bit of lag....
24-05-2007, 12:52 AM | #16 | ||
Non-Regular Member
IIRC LS is drive by wire too
24-05-2007, 06:54 AM | #17 | |||
Mr Focus
Im not a fan as well. What else are you going to do to the engine?
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody Oz racing: WRC OBX: 4-2-1 race header SCT: xcal3, dash scan. |
24-05-2007, 09:49 AM | #18 | |||
AFF Post NAZI
24-05-2007, 02:19 PM | #19 | ||
Focus Rookie
Got it done this morning... and woah it makes a difference.. its like pressing the sport button or something.. instead of stomping on the throttle and waiting a half a second to rev.. its instant.. i was doing burnouts all the way to work..
also had my spark plugs done and got my lights fixed.. Havent noticed much of a power increase.. but i havent too hard,,
24-05-2007, 04:43 PM | #20 | ||
Focus Rookie
Ahh yer and according to the Auto Electrician the PreDrilled hole was 0.8V out.. So they redriled another set
24-05-2007, 07:26 PM | #21 | |||
Zoom Zoom
2012 Mazda3 MPS
25-05-2007, 11:16 AM | #22 | ||
I figured the standard opening on the LS is about 55mm which is enuf flow for over 180 HP it's not worth messing with the standard TB. Working upstream the flex airhose and filter box could use some werk. I was thinking of an under bonnet pod connected by smooth silicon hose to TB but again I felt the gains would be small.
One day I might take the airbox off to a flow bench test and see for real what gains are lurking there. I think the head flows ok as standard from what I read somewhere - 200 HP with 4 x TB and 3rd party ECU. The rest of the engine was completely standard, they didnt even take the cam covers off. 4 x TB would be a cheaper alternative to turbo I think wouldnt it? |
25-05-2007, 08:33 PM | #23 | ||
AFF Post NAZI
They are worth quite a Few Quid mate... looking at a couple of G.
27-05-2007, 10:37 AM | #24 | ||||
Mmmmmmmm.........so it does work....if only it were a bit easier to put in...nyway thanks for letting us know...I still got it in mind...bloody held up with moving....would be doing it (TB) sometime soon Some have had sticky throttles.....ny probs like that? Quote:
2" catback...yeah want that as well......so many plans...so little money :
