20-05-2007, 08:33 PM | #1 | ||
Old enough to know better
Well, I think my clutch is on the way out. Started slipping in 5th gear today along the freeway (accelerate in 5th and it starts slipping). Not dead yet, but the writing is on the wall
Adam and Matt, from memory you've both replaced your clutches. Any tips from anyone? eg Stay genuine? Aftermarket? Best options? Things to look out for? etc etc
21-05-2007, 12:12 AM | #2 | ||
WRC1AB
Aftermarket option:
http://replacement.autopartswarehouse.com/parts Most Ford Focus clutch kit options are listed here. This should give you some idea.Personally I haven`t changed my clutch yet and I`m close to 90 000km.
[ :eclipsee_ : :eclipsee_ LR Focus |
21-05-2007, 05:17 PM | #3 | ||
Mr Focus
Well Ford Racing has Original equipment and aftermarket parts.
Not sure how long Ford Racing will keep making Zetec parts for.
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody Oz racing: WRC OBX: 4-2-1 race header SCT: xcal3, dash scan. |
21-05-2007, 05:29 PM | #4 | ||
Steve my clutch only when because the clutch springs went on me. Other than that I had plenty of meat left on the clutch. I don't mind the orginal clutch. Should've went aftermarket heavy duty clutch. It would probably be cheaper but the original is good. Shop around and see what you can get for the price. A thing I hate about my car is the noisy thrust bearing and costs $130 if i remember correctly for that. So get that checked as well Steve.
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
21-05-2007, 11:51 PM | #5 | ||
Zoom Zoom
My clutch went after I taught a girl to drive. Never again. Original clutch not an issue, it's not like I do burnouts anyway.
2012 Mazda3 MPS
22-05-2007, 06:15 AM | #6 | ||
Mr Focus
Did she drop your gear box on the road...TeeHee
22-05-2007, 08:12 AM | #7 | ||
Are you saying I drive like a girl Matt??!! LOL
13-06-2007, 06:26 PM | #8 | ||
OK guys. I have a choice.
Motorcraft clutch kit fitted by Ford Dealer. approx $1200 + (could be more depending on how much machining needed on flywheel) Exedy clutch fitted by ABS in Moorabbin. $1211.Includes machining Any advice?
13-06-2007, 06:35 PM | #9 | ||
Mr Focus
Don't you want a Windsor centerforce clutch kit?
13-06-2007, 07:57 PM | #10 | ||
AFF Post NAZI
Go the ford steve... that way if it stuffs up then Ford are to blame and they cant do anything about it.....
15-06-2007, 12:45 AM | #11 | ||
exedy clutches are really good, i used to have one on my old car, if you can install it yourself or know someone that can to drop the price becausethe cost price wouldn't be over the $400 mark for the parts
: Don't yell, i'm probably hungover |
15-06-2007, 09:45 PM | #12 | ||
Machine costs about $40 thats how much I paid for mine when I got it done.
