Old 30-06-2007, 12:10 PM   #1
slo351
slo351's Avatar
Default kill switches..
i know with all the factory ford immobilsers/ central locking etc that my ute is sort of safe but im thinking of installing another kill switch for piece of mind..
is it worth it ? and how safe are Au's ?? even if i put a switch to cut out fuel pump, sure it might start for abit.. but that's all the suckers would get if they managed to take it
slo351 is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 12:17 PM   #2
superroo
You can't stop the signal
superroo's Avatar
i reckon best sensor to kill would be the crank angle sensor, won't even be able to start then.
It's all up to you, i've considered doing it but just haven't been assed enough to do it.
Old 30-06-2007, 12:20 PM   #3
Hibbz
The Mod Bug Has Hit
Hibbz's Avatar
It might be worth it but i think if they can break in it and actually start it they probally would not take them that long to find a kill switch.
Jake
www.aufalcon.com/jakesfalcon
Hibbz is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2007, 12:22 PM   #4
JC
Miami Pilot
JC's Avatar
Don't need to start it at all if you have a flatbed.
Ford Performance Club ACT
Old 30-06-2007, 12:44 PM   #5
slo351
slo351's Avatar
haha i cant be stuffed doing it either.. but is something does happen one day then i will be 'not happy jan' hahaha
i was just looking for something i can tap in under the dash too.. whether or not the BCM has something, as i dont want to run wiring all through out the car..
Old 30-06-2007, 01:00 PM   #6
FGII-XR6
FGII-XR6's Avatar
if it's an AU2/3 don't bother you can't start them without the transponder only way of taking one without the key is to tow it
Old 30-06-2007, 01:57 PM   #7
b2tf
not here much anymore
b2tf's Avatar
Probably not a neccesary thing on an AU and I reckon it would be a fair bit of mucking about, Smartshield doesnt like being messed with all that much.
If you're really worried, get yourself a good alarm with an immobiliser and whack that in, comes with everything you need, and if its an approved one, you will save a bit on insurance too.
2024 F150 XLT
Old 01-07-2007, 08:51 AM   #8
EvilChief
Boost Addict
wiring for CAS are shielded to eliminate interference. if u add a switch into that shielded system you may introduce interference in the CAS signal, causing misifiring, rough ideling, hard to start or not at all, etc
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build)
Ford BA XR6T Ute - daily driver
Ford FG XR6T Sedan - cruiser
do you see a general trend? I DO
Can't live with it, can't live without it!
EvilChief is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 09:53 AM   #9
Stav
Smile
Stav's Avatar
Cut the fuel pump and install the switch with relay. Then get a second switch and kill the kill switch but hide it in a good spot.Evn if they find the obvious kill switch the kill kiil switch will be workng.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 01-07-2007, 11:02 AM   #10
robbo_yobbo
Kick out tha Jams
robbo_yobbo's Avatar
I used to think like that, that is untill my car got stollen. They didnt get far, only about 500 meters and then took out my entire drivers side.
Im not sure how they did it, as there was no ignition damage, but all the wiring harnesses were unplugged, so my thought is they brought along thier own transponder, bem and ECU, unplugged mine, plugged thiers in, used a skeleton key to unlock the steering lock, and bobs your sister!
Only thing is, it sounds like a professional thing to do, but crashing within 500meters doesnt.
Id hook up a switch to kill the fuel pump, kill the coil pack, kill the earth to the ECU, and kill the starter motor. then if they can get around the factory kills, they have another 3 to find if unless they can locate your kill switch, so to get around that, I a like the idea of killing the kill switch with a second switch!
$416.80.......All that cash came from a new (used) car. Check your back seats!
robbo_yobbo is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2007, 09:18 PM   #11
CMYAU3
Tyre Shredn
CMYAU3's Avatar
put a switch on the relay for the fuel pump. it wont do anything then.
au's take 5 mins to get into. : they re to easy. but i wouldn't think it would that easy drive off in with out a key. alarms are good to scare people off. if you really want to make it hard take out your key lock the steering and pump the brakes pedal until it locks up the brakes.
CMYAU3 is offline   Reply With Quote Multi-Quote with this Post
