Old 10-07-2007, 09:44 AM   #1
plee
plee's Avatar
Default Engine Warning Light
Hi,
I have a Manual LS Focus CL and the Engine Warning Light has come on. I have done about 22,000kms and the car still seems to be running smoothly. I have booked the car in for somebody to have a look at it, but was just wondering whether anybody on here has had anything similar happen with their car. I am using 95 Unleaded primarily with a bit of 98, have had the car starting issue a few times, but nothing recently.
Any recommendations/advice would be appreciated.
BF Fairmont Ghia 2006 - Lightning Strike
plee is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2007, 10:05 AM   #2
photn
AFF Post NAZI
photn's Avatar
might just be a loose sensor cable or some what. but its good that you have booked it in.... get it checked out...
Old 10-07-2007, 04:26 PM   #3
BlackLS
Posts: n/a
Sounds like the throttle position sensor. A few other members have needed their's changed. Does it happen at startup onward or only after driving for a little while.
http://fordforums.com.au/showthread.php?t=65958
Old 11-07-2007, 08:26 AM   #4
plee
plee's Avatar
Well the light is on all the time now, but Ive had the car starting problem a few times recently.
Old 11-07-2007, 03:18 PM   #5
More revs
If it drives ok just remove the lamp so it wont bother you again...
joking ha ha
The starting problems may be the fuel pickup in the tank which is a very common problem on the Focus - when I say problem I mean 'feature' Mine does it whenever I park it nose up anywhere, have to crank it over and over before it starts.
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2007, 09:38 PM   #6
FocusLX06
FocusLX06's Avatar
The engine warning light switched on in our Focus a few days ago, stayed on all night (we were ages from home) and then was off the next morning. We'll be getting ours looked it soon for a range of issues.
Current car: 2022 Escape st-line - Previous Fords: 2006 Focus, 2009 FG XR6T, 2009 Focus, 2012 Focus, 2016 Territory
FocusLX06 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2007, 11:26 AM   #7
plee
plee's Avatar
Well it's being repaired today, they are putting a new EGR valve in. If anybody wants any more info on what this is, I've found this site...
http://www.focushacks.com/index.php?modid=80
