Old 25-03-2009, 10:23 PM   #1
R0BD0G
R0BD0G's Avatar
Default escort steering racks MK1 and MK2 problems?!!??!?!?!!?
we have the volvo conversion brakes on my escort which is also on mk2 1600 struts and hubs. problem is is that the tie rod ends off the mk1 or too sloppy in the hole on the wheel hub. the mk2 ones fit perfct but wont screw into the rack ends. how have people gotten around this problem previously.
can the mk2 rack ends be put onto a mk1 rack?
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 25-03-2009, 10:37 PM   #2
JamesR
you need to either use a MK2 steering rack, or get some 'Green' tie rod ends.
see link below, goto steering section on the left.
http://www.smckaperformance.com.au/
1977 MkII Escort Ghia.
2006 MY07 Subaru Liberty GT Spec B wagon.
my photo blog;
http://www.jamesruff.net
JamesR is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2009, 09:28 AM   #3
outback_ute
Ute Forum Moderator
Contributing Member
outback_ute's Avatar
Something deep in my memory tells me Mk1 used imperial dimensions and Mk2 metric - would this be right?
outback_ute is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2009, 05:15 PM   #4
R0BD0G
R0BD0G's Avatar
mk2 is a coarse thread at the rack and mk1 is fine
Old 26-03-2009, 05:17 PM   #5
R0BD0G
R0BD0G's Avatar
from smcka
New 'green' tie rod ends, required when fitting a Mark 2 Escort rack to Capri or mark 1 Escort struts which an imperial taper on the steering arm. Green tie rod ends have a metric thread and imperial taper. Brand new reproduction items.
we have mk2 struts and hubs and a mk1 rack.. so wouldnt work yeah/
Old 26-03-2009, 06:01 PM   #6
JamesR
Originally Posted by R0BD0G
from smcka
oh shi..
sorry. got mixed up. :
my photo blog;
Old 26-03-2009, 07:40 PM   #7
R0BD0G
R0BD0G's Avatar
i cant be the only one to ever have this problem so there would be a quick fix i hope
Old 26-03-2009, 08:53 PM   #8
johno9184
74 mk1 2 door escort:
will a mk 2 rack fit and replace the mk1?
johno9184 is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2009, 09:21 PM   #9
R0BD0G
R0BD0G's Avatar
checking with smcka now anyway. dont want to put a mk2 rack in it
Old 30-03-2009, 11:13 PM   #10
whooligan
whooligan's Avatar
Essentially they are exactly the same as a Mk 1 rack. Sounds like the easiest solution to your problem.
I'm doing the opposite. Fitting Capri struts in my Mk 2, so I'm swapping the Mk 2 rack for a Mk 1 rack. Green tie rod ends are usually the way around this problem, but if you need to replace them in a hurry, you can't just go into autobarn and buy a new set off the shelf. Stupid wheel alighnment guys tend to get a bit sloppy with the hammer every now and again and they insist on replacing tie rod ends. Swapping the rack keeps it simple and cheaper in the long run.
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2009, 07:59 PM   #11
R0BD0G
R0BD0G's Avatar
can you change the rack ends?
Old 01-04-2009, 01:16 PM   #12
Puzzlescort
Rally Nut
Puzzlescort's Avatar
You can change the rack ends, but if your doing that you will need to keep doing that if you need to replace the rack at any stage
The easiest thing to do is to replace the Mk1 rack with a MK2 item
that way you have a stock standard item in there
Mk2 racks are a dim a dozen, i have thrown that many out its not funny, you can always upgrade to a quick rack - shop around $275 - $330
Puzzlescort is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 11:37 PM   #13
ratta tat tat
So the green tie rod end won't work when trying to marry MK2 struts to MK1 steering rack?? The item discription is a little confusing.
ratta tat tat is offline   Reply With Quote Multi-Quote with this Post
Old 10-06-2010, 07:12 AM   #14
Puzzlescort
Rally Nut
NO the 'green' tie rod ends will work when fitting capri or MK1 struts to a MK2 escort
I just had the steering arms on my GP4 struts machined to suit MK2 tie rods
