Old 29-06-2010, 03:51 PM   #1
LASGT8
450rwk
LASGT8's Avatar
Default BA XR8 front calipers fit AU XR8
Howdy,
Can anyone tell me if BA series1 XR8 front calipers,rotors and pads will direct fit onto AU seriers1 front or what I would have to do to get it to fit???
Scott
LASGT8 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2010, 04:58 PM   #2
sleeper393
sleeper393's Avatar
Exclamation
you need the whole upright that the hub bolts to, as the caliper mounting holes are spaced further apart , ba caliper is alot larger , with smaller lighter pistons i put the ba ones on my au s/3 if you can get them cheap they are good little upgrade. i picked my ba hubs , uprights , calipers , front & rear for $56.00 of ebay , wreckers will charge you like a wounded bull , you wouldn't even get a single caliper for that price , cheers
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak!
AU SERIES 3 LIQUID SILVER
BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS
123.4 GROUND TEARING RWKW'S , LOL
sleeper393 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2010, 05:16 PM   #3
LASGT8
450rwk
LASGT8's Avatar
cheers for that i got everything already except for uprights.
Old 29-06-2010, 06:53 PM   #4
Auturbo6
The only thing u'll see!!
Auturbo6's Avatar
On the six cylinders everything just changes over, Ive installed BA XR6 front brakes on my AU and it all just bolted up.
Auturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2010, 07:48 PM   #5
superroo
You can't stop the signal
superroo's Avatar
On series 2/3 cars the callipers will be a direct change.
On series 1's though it is change the front suspension. That is sway bar + mounts, lower arms, uprights, and braking system (including lines).
Here's a thread on what's needed and how to do it.
http://www.fordforums.com.au/showthr...69#post2720169
Old 30-06-2010, 09:18 AM   #6
crdave
Blue Blood
crdave's Avatar
So would BA XR6 or 8 brakes be a good upgrade on an AUII Fairmont Ghia?
crdave is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2010, 11:14 AM   #7
superroo
superroo's Avatar
They are an alright upgrade if you can get the parts at a good price.
This is because they are not much larger than au2/3 stuff. 298 Vs 287. But looking at the calipers, they look like they would be stiffer than the au2/3 calipers, but that is my own sumising. You'd be hard pressed to tell that from within the car though.
The good upgrade if you can get them are either the BA premiums/GT brakes (black or blue PBR caliper), or BF XR6T/XR8 calipers.
The premiums are 325*32, and the BF gear is 322*28
Old 30-06-2010, 12:06 PM   #8
crdave
Blue Blood
crdave's Avatar
Cheers for the info. Sorrry about fastxr8
Old 30-06-2010, 08:15 PM   #9
Auturbo6
Auturbo6's Avatar
Man theirs a sizable difference between AU and BA front rotors. Even BA Xt rotors and calipers will make a difference, esspesially on mountain runs.
Old 30-06-2010, 09:04 PM   #10
JC
Miami Pilot
JC's Avatar
Originally Posted by Auturbo6
Man theirs a sizable difference between AU and BA front rotors. Even BA Xt rotors and calipers will make a difference, especially on mountain runs.
Yeh, a whole 11mm. Rotor size is the same between AU1 and AU2, but AU2s gets the twin pot callipers. Not much point going from AU2/3 to BA (except for the "I did it" factor), but going from AU1 to AU2 or BA, just for the front twin pots is a great improvement.
AU1 pads are 130 x 62 x 13 mm
AU2/3 Pads are 169 x 62 x 16 mm
BA pads are 190 x 58 x 15 mm (longer but not as wide as AU2)
BF XR8 pads are 184 x 63 x 14 mm
Ford Performance Club ACT
Old 30-06-2010, 09:31 PM   #11
sleeper393
sleeper393's Avatar
Thumbs up
i've put ba setup on my AU S/3 , only cause my originals were shot , as above i got the whole ba setup for $56, reco'ed them still worked out cheaper than fixing the AU ONES ,had the braking system tested on a brake retarding machine they definatly showed better braking improvement , for a small outlay.
Old 01-07-2010, 02:43 AM   #12
JC
Miami Pilot
JC's Avatar
$56 is an extremely great price, and certainly hard to go past!
Old 01-07-2010, 06:39 PM   #13
Auturbo6
Auturbo6's Avatar
11mm is 11mm, every little bit helps. Or just don't bother at all, who needs to stop. Only girls use the middle pedal anyway. Later.........
Old 01-07-2010, 06:49 PM   #14
sleeper393
sleeper393's Avatar
Talking
[/B]SPEED DOESN'T KILL ITS THE SUDDEN STOP AT THE END !
