Old 06-06-2011, 09:32 PM   #1
13101093
13101093's Avatar
Default AU ute diff replacements?
Hey people
I was wondering if anyone can tell me what diffs are compatible with an AU ute.
will wagon diffs fit? are there different handbrake setups out there? different tailshafts setups?
cheers
frank
13101093 is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2011, 09:42 PM   #2
Papa Smurf
Papa Smurf's Avatar
Default Re: AU ute diff replacements?
BA Utes and Wagons up to 10/2005 use the same housing so I can't see why you couldn't use a BA Wagon or Ute diff or an AU wagon diff assy.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2011, 05:18 PM   #3
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
What he said, but the handbrake mounting points are slightly different from wagon to ute, and maybe even from AU to BA.
It's only slight though and extremely easy to overcome.
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2011, 10:44 PM   #4
bartsau
bartsau's Avatar
I can tell you that I put an LSD from a ute into my wagon originally and everything bolted straight in. If there was a difference I couldn't see it. This was an AU diff into an AU wagon though. Apart from the handbrake set up on newer models everything else will still bolt up without any problems.
Rhys
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
Old 10-06-2011, 09:06 AM   #5
Sox
RIP...
Sox's Avatar
Rhys
You're right, the difference is not between wagon and sedan, rather AU to BA. I'm confusing myself.
The difference is where the handbrake brackets are mounted.
Oval Everywhere...
Old 10-06-2011, 02:52 PM   #6
13101093
13101093's Avatar
cheers for the help! this should turn out cheaper than a diff rebuild
