19-09-2011, 08:14 PM | #1 | ||
V8's for ever
http://www.ebay.com.au/itm/FORD-ESCO...item20bcd29767
Hi all, can anyone tell me the effect of fitting this master cylinder 20.6mm bore to a Mk2 Rs2000 with a 19.05mm bore ( I think its that size) Will this work or create problems with the braking system. I am trying to track down a new master cylinder ans also rear drum wheel cylinders but they are a bit scarce. Cheers Shep |
20-09-2011, 08:16 PM | #2 | ||
Tippy-tronic Free Zone
If having problems, just get them - master or rear wheels - relseeved in stainless.
Caution with changing bore diameters without changing the rest of the system to match. The Ford engineers spend a lot of time getting the cylinder capacity relationships correct. On another thread there is a discussion about changing lots of components from other various/different cars...and then having problems. |
