29-10-2005, 07:39 PM | #1 | ||
Life's a Gas
Any external identification?
I thought I read somewhere that the AUII Fairmont Ghia V8 had LSD as standard, but I might be wrong... |
29-10-2005, 07:47 PM | #2 | ||
Miami Pilot
The filler hole should have a bolt in it. If it's an LSD, it will also have a metal tag attached to the bolt advising that it's an LSD. If it's got an IRS setup, then the filler hole is on the LHS of the diff, near the tailshaft.
29-10-2005, 08:16 PM | #3 | ||
Former BTIKD
Jack the entire rear of the car off the ground and turn one wheel, dont start the car!, if the opposite wheel turns the same way its LSD.
Or you could try laying some rubber and see if it makes one black line or two
29-10-2005, 08:24 PM | #4 | ||
Option 3: Find a roundabout when the road is wet. Enter the roundabout, turn right and give it a boot full of accelerator at the same time:
- if the inside rear wheel spins then your car does not have LSD - if you find your **** end hangs out big time or you have spun the car then your car is fitted with LSD. FF |
29-10-2005, 09:05 PM | #5 | ||
TL40 Wagon?
Look if you have to ask you haven't got one.
You would notice it in lots of little way reversing up a hill steep driveway in the wet. RH turns uphill in the wet and roundabouts. when AUII came in with traction control out went the LSD except by option on quite a few models in the range. |
29-10-2005, 09:53 PM | #6 | |||
Posts: n/a
30-10-2005, 01:05 PM | #7 | ||
see i dont know if minehas either, the other day i laid 2 black lines.
other times in the wet, only right wheel spins.. WHY? |
30-10-2005, 07:15 PM | #8 | |||
Audi S3
30-10-2005, 07:19 PM | #9 | |||
reece1
30-10-2005, 09:22 PM | #10 | |||
FF |
30-10-2005, 09:26 PM | #11 | |||
Former BTIKD
30-10-2005, 09:54 PM | #12 | |||
reece1
30-10-2005, 10:01 PM | #13 | ||
Back on the road
Isn't there supposed to be a "Warning: LSD Fitted" type sticker inside the drivers side door-frame?
Just rip off a big burnout on your favourite non-public test track i.e. neighbours driveway. One black line = open diff, two black lines = LSD ;)
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
30-10-2005, 10:23 PM | #14 | ||
from what i can gather after having a ZL fairlane with LSD and my current AU fairlane without LSD from the feel of it.. and my NA fairlane i had previously without LSD
the LSD equipped vehicles have a tendency to get the *** out ANYTIME the wheels start spinning... (off the line especially) and the tyres scrub slightly during slow tight turns esp on gravely covered roads..also if u put 1 wheel on the dirt and hte other wheel on the tarmac.. the wheels WONT spin just accelerate at a constant speed.. where as the NON LSD cars tend to just go STRAIGHT AHEAD..and the inside tyre chirps when u give it heaps out of any corner there is a tag on the diff that faces toward the left wheel well on my AU fairlane that states it has a 3.45 ratio but not much more than that(couple of numbers and stuff) easiest way is to jack the *** up and spin 1 wheel if the other spins the SAME way its LSD |
31-10-2005, 08:10 AM | #15 | ||
Life's a Gas
Thanks fellas. Car has traction control, so it probably doesn't have LSD. When I feel a bit energetic I'll look for a tag and/or jack the back end up.
03-11-2005, 10:37 PM | #16 | ||
my guess is a AUII Fairmont Ghia V8 could cut a double legger if it had a LSD so just do it. If both wheels spin = LSD (normally) If right spins = No LSD (normally). a non LSD cutting both wheels can mean a stuffed diff or it could just be weird.
03-11-2005, 10:38 PM | #17 | ||
lol or you could do it any of the normal ways that every1 else has said..
