Old 25-10-2011, 03:06 PM   #1
rayban76
AU3 5.0L Fairmont Wagon
rayban76's Avatar
Default Steering Wheel Control Wiring
Does anyone know what wires on the plug to the stereo are for the steering wheel controls?
I have a AU3 Fairmont with an aftermarket TFT Stereo and I want to hook up the steering wheel controls to it.
Thanks
5.0L, 2.1l Kenne Bell, Tickford T3 Heads, Crow valve springs, YellaTerra 1.7 Rockers, Comp Cam, Comp D-Row Timing, 10mm LiveWire Leads, LC-1 & Moats Quarterhorse, B&M TransCooler, Walbro 255lph Fuel Pump, King Superlow Coil Springs, John Bowe Superlow Pro Leaf Springs, K&N 4" Pod & CAI, Pacemakers, 100c Cats, 2.5" Redback, 19" FPV Rims, BF-T Prem Brakes, TS50 Bumper with DTRL's, Custom FG Bulge, BA XR Side Skirts/Rear bar
Ford Performance Club of ACT
[SIGPIC][/SIGPIC]
rayban76 is offline   Reply With Quote Multi-Quote with this Post
Old 25-10-2011, 06:47 PM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: Steering Wheel Control Wiring
you need an interface to interpret the signals . this is one suited to your needs http://www.thecat.net.au/home.htm you can't just hook wires up
[SIGPIC][/SIGPIC]
Rides:
Old 25-10-2011, 07:19 PM   #3
b2tf
not here much anymore
b2tf's Avatar
.............and sit down when you price one. they're not cheap.
RAM 1500
Old 26-10-2011, 08:03 PM   #4
FGII-XR6
FGII-XR6's Avatar
so true but they work like a dream if you use direct connect
[SIGPIC][/SIGPIC]
Rides:
Old 27-10-2011, 10:19 AM   #5
rayban76
rayban76's Avatar
Thanks guys, I have had a look, but not sure if it will work with my headunit, mine is the same as this
http://www.ebay.com.au/itm/250574738...84.m1423.l2649
so it's kind of a generic brand, however allows for direct plug in with a 3.5mm Jack.
Does anyone know where you can buy these from as I've done a search and cant find them (or a price)
[SIGPIC][/SIGPIC]
Old 27-10-2011, 10:47 AM   #6
b2tf
b2tf's Avatar
Generally the units need to be able to receive a signal from a remote, and this is what the CAT unit grabs to 'talk to' the steering wheel controls.
RAM 1500
Old 27-10-2011, 11:08 AM   #7
rayban76
rayban76's Avatar
ok cool... well mine has a remote but also has the rear jack imput for the steering wheel...
I'll have to see if I can find one I guess.
[SIGPIC][/SIGPIC]
Old 27-10-2011, 01:24 PM   #8
ronwest
All Bran = Regular Member
I bought a cat09 from JBHifi a few years ago @ $200. It was replaced under warranty with a Cat10 which at the time had a price sticker on it @ $240.
The Pac unit may be an option for you but as with the Cat you'd have to verify it's compatibility http://www.mobileelectronics.com.au/...-pac-swi-jack/
ronwest is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2011, 01:50 PM   #9
rayban76
rayban76's Avatar
Thanks Ronwest, i'll have an look and see if it will work.
cheers
[SIGPIC][/SIGPIC]
Old 28-10-2011, 05:08 AM   #10
FGII-XR6
FGII-XR6's Avatar
here it is http://www.ebay.com.au/itm/Stinger-C...item3cbcfc51bd
[SIGPIC][/SIGPIC]
Rides:
