Old 29-11-2011, 04:00 PM   #1
aufreddy
Default gt4o manifold,HELP!!!
Hi fellas dunno if this thread has been on before so here goes.Have got a gt40 tubular manifold pulled the explorer off,done all the plumbin and found out it wouldnt fit because it sits on the heater pipes that run down the side of the lower manifold,anyone got any ideas!! Freddy
aufreddy is offline   Reply With Quote Multi-Quote with this Post
Old 29-11-2011, 07:52 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Re: gt4o manifold,HELP!!!
Would one of the Phenolic (spellin) spacers lift it enough to clear ?
Originally Posted by Riksta
Old 30-11-2011, 09:05 AM   #3
aufreddy
Hi woosha it had an 1\2" spacer on it, wouldnt fit it under the bonnet with a higher spacer dont think! Thanks for your reply,Freddy
Old 02-12-2011, 05:00 PM   #4
b2tf
not here much anymore
b2tf's Avatar
Can you adjust the hoses at all? I'm also curious as to how/where you got the manifold, wouldnt mind one for my ute.
2024 F150 XLT
Old 05-12-2011, 03:33 AM   #5
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Do you have aftermarket rocker covers on it. when i put my au motor in my eb i put sheet metal rocker covers on and the plenum wouldn't fit without a 1in spacer, fits under the eb bonnet no probs. throw standard covers on if this is the issue and it should clear.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
