19-02-2012, 03:10 PM | #1 | ||
Okay I know what this part is for, but I do not know its name.
Today I changed all the coolent hoses, Water Pump and Heating Tap but on closer inspection of this unnamed part, I feel I should replace it too. So if you can name it I can buy it. Thanks, Edit:Spelling
BUILD AU II FAIRMONT GHIA HERS AU II Fairmont Ghia 7" DVD/GPS Radio 19" Wheels HIS FG XR8 Ute Lux Pack Tech Pack Touch Screen GPS Last edited by rmack; 19-02-2012 at 03:21 PM. |
19-02-2012, 03:32 PM | #2 | ||
When in doubt, GAS IT!!
That's the pipe that feeds the heater. I'd guess and call it the heater inlet pipe. There's a corresponding one on the other side of the block that feeds back into the water pump. That I'd call the heater outlet pipe........ but I don't know what the parts catalogue would list it as.
Why do you think it needs changing anyway? Bushbasher
19-02-2012, 03:39 PM | #3 | |||
The reason why I want to replace it, is that it is badly corroded on the heater tap end,
BUILD AU II FAIRMONT GHIA HERS AU II Fairmont Ghia 7" DVD/GPS Radio 19" Wheels HIS FG XR8 Ute Lux Pack Tech Pack Touch Screen GPS |
19-02-2012, 04:54 PM | #4 | ||
Okay I found this in the parts database
Part #EF 18C266 A Description: HOSE ASSY HEATER So the next question. Is the EF part the same as an VCT AU????
BUILD AU II FAIRMONT GHIA HERS AU II Fairmont Ghia 7" DVD/GPS Radio 19" Wheels HIS FG XR8 Ute Lux Pack Tech Pack Touch Screen GPS Last edited by rmack; 19-02-2012 at 05:14 PM. |
19-02-2012, 05:32 PM | #5 | |||
Wrong Part Number Part #EF 18696 A Description: TUBE HEATER INLET
19-02-2012, 05:39 PM | #6 | ||
meh.
EF and AU share the same part - I'm running an EF thermostat lower heater pipe on an AU VCT engine..
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
19-02-2012, 10:18 PM | #7 | ||
i have a brand new AU one sittting here as a spare, part number WR2A 18696 AA
Money Talks, but all i ever hear is it saying Goodbye!! |
20-02-2012, 10:36 AM | #8 | ||
Just out of interest...what's one of these worth? Mine had a minor leak at the thermostat housing end too, I globbed it up with some form-a-gasket type 2, but I don't expect the fix is going to last too long.
20-02-2012, 09:01 PM | #9 | |||
21-02-2012, 01:02 PM | #10 | ||
That heater pipe you'all are referring to has a rubber seal fitted at the thermostat end. This seal can be bought very cheaply (even at Ford dealers), and get replaced.
I replaced mine around a year ago, after it started to leak, increasingly! Cheers, 4ford |
21-02-2012, 04:44 PM | #11 | ||
Mine is leaking at the other end. The pipe has corroded through and has a small fracture which leaks under pressure.
21-02-2012, 09:48 PM | #12 | |||
22-02-2012, 09:57 AM | #13 | |||
24-02-2012, 01:26 AM | #14 | ||
Bugger!
The pipe is exactly the same from EA-AU. Not sure about part numbers, but fitted an EA one to an AU s2 ute a couple of weeks ago....
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 |
26-02-2012, 07:33 PM | #15 | ||
Fitted the replacment part today. As stated above $65.00 inc GST
